goodnurse
#1 Posted : Saturday, January 16, 2010 8:54:09 AM(UTC)
goodnurse
the clean light keeps flashing, manual says that the heater circuit is faulty. what part(s) do i need to repair.
thanks
#2 Posted : Saturday, January 16, 2010 10:08:17 AM(UTC)
Replacement parts for WHIRLPOOL DU1145XTPB6 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208535451.pdf
Can be a number of things: the heater itself, the hi-limit thermostat, the thermistor or the board itself. If the dishes are drying correctly, the the first two item are unlikely.
First remove power from the unit for half an hour or so to see if it will reset.
Try diagnostics in the tech sheet.
Measure the components with a meter.
