| » KitchenAid Dishwasher |
Model Number: KUDS230Y2 Brand: Kitchen Aid Age: 5 - 10 years
How do you check and adjust for the proper water level in dishwasher. Currently, water is pouring out of the overflow assy. on to the kitchen floor. All over flow parts are new, stand pipe and float.
Thank you, Kenny steinl88@yahoo.com Ads By Google Related Models |
There is no adjustment for fill level, the fill is regulated by time and they assume the water pressure/flow will be at a normal rate to give the correct fill level.
The overfill switch/float should not be activated in normal use. It is usually just a safety device. Here are your parts Pump and motor replacement parts for WHIRLPOOL KUDS230Y2 | AppliancePartsPros.com Here is the tech sheet http://www.servicematters.com/docs/w...%209741531.pdf Check to ensure that the unit is not leaving water in the tub after a drain cycle. You may have a partial drain plug. The most common place for this is where the drain hose enters the house plumbing. Check that the fill valve is not leaking re: it is empty after a wash cycle and then overnight water leaks into the tub. Check that the drain tube is looped minimum of 10 inches higher than where it enters the house plumbing. Could be it is siphoning water back into the unit or there is a partial house drain plug or it is overflowing back into the unit. If the unit is attached to an air gap, check/clean it.
__________________
| Display Modes | |
| kitchenaid dishwasher | michael campbell | Dishwasher Repair | 0 | 01-24-2010 09:05 AM |
| kitchenaid dishwasher | joshwht | Dishwasher Repair | 1 | 11-30-2009 06:04 AM |
| Kitchenaid Dishwasher | mh3488 | Dishwasher Repair | 1 | 05-12-2009 10:33 PM |
| Kitchenaid dishwasher | stephen081@centurytel.net | Dishwasher Repair | 0 | 01-22-2009 05:59 PM |
| Help with kitchenaid dishwasher | dilksy | Dishwasher Repair | 0 | 12-16-2008 07:09 PM |
