The control board burnt up, it appears one the the relays on the board stuck,shorted and burnt the lower side of the curcuit board. No wires showed signs of heating or melting. The plastic ribbon to the exterior buttons did not melt. I purchased and replaced the curcuit board. Closed the door pushed the smart wash button turned off the heat and pushed start. The machine started filled with water and started to wash. I let it run for a few minutes and open the door the machine stopped. Thought I had it fixed. Waited till after supper and started to put dishes in the unit but now the normal wash lite is blinking fast. I push the start button no response. I go shut off the breaker wait a few and turn it back on. Smart lite is on I push start nothing happens and then it goes to blinking normal wash lite again. Shut breaker off again, turn on and go hit cancel button the machine removes the water. Now after a minute or so normal wash lite blinks again. You have to remove power to get it to stop. The only buttons to work now is the cancel and the delay button. Hit cancel the washer lite comes on but if you leave it go it turns the normal wash lite to blinking. Any ideas??
