| » Bosch SHU5312 - stuck in cycle |
Model Number: SHU5312/U12 Brand: Bosch Age: 5 - 10 years
Recently my Bosch SHU5312/U12 started showing a 2h cycle time when starting a regular wash cycle. It use to say 91 (for 91 minutes) it then runs for 2hrs but gets stuck at the 1 min point and continues to run. We cancel the cycle, it then drains out and quits. I have read here that this may be a heater or controller board problem but had no seen where the cycle time has changed. Any ideas? BTW - the controler board was replaced at year 1 under warrenty.
Related Models Last edited by DanS2 : 03-31-2008 at 07:03 PM. Reason: incomplete |
Most likely the problem is a bad control module. This is one of most common problems with Bosch dishwashers.
- The part number for the control module is AP2802870 Gene.
__________________
Professional appliance repair in Orange County, California. |
You'll find that the circuit board behind the display has a burned solder joint on the relay junction. I repaired mine using some solder and a short piece of wire. Works fine and probably much more reliable than the original install.
If you own and can operate a soldering iron, you probably posses the rest of the skills to fix this yourself. |
| Display Modes | |
| Dishwasher gets stuck in cycle | woodieb1 | Dishwasher Repair | 4 | 05-10-2008 08:44 PM |
| Bosch dishwasher stuck on rinse cycle | JDDrake | Dishwasher Repair | 2 | 04-05-2008 11:10 AM |
| My Bosch dishwasher is stuck! | kevin e | Dishwasher Repair | 5 | 04-04-2008 06:09 PM |
| stuck in drain cycle | kyrboyd | Dishwasher Repair | 0 | 12-30-2007 10:27 PM |
| Stuck in drain cycle | glbray1 | Dishwasher Repair | 0 | 11-04-2007 09:38 AM |
