Discuss
My Bosch dishwasher is stuck!
 in
Dishwasher Repair
My bosch dishwasher gets stuck at the 1 minute mark of the cycle. Ijust keeps going and going. Can someone
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » My Bosch dishwasher is stuck!
  #1 (permalink)
Old 03-29-2008, 02:43 PM
Junior Member
kevin e is on a distinguished road
Default My Bosch dishwasher is stuck!
Model Number: shu5315uc/06   Brand: Bosch   Age: 5 - 10 years
My bosch dishwasher gets stuck at the 1 minute mark of the cycle. Ijust keeps going and going. Can someone tell me which part I need to fix this problem? I am very handy but I am just getting into appliance repair. Thanks, Kevin
Ads By Google
Related Models
Bosch SHU5316 UC/06
Bosch SHU5316 UC/11
Bosch SHU5316 UC/12
Bosch SHU5317 UC/12
Bosch SHU53A02 UC/14 (FD 8211-)
Bosch SHU53A05 UC/14 (FD 8211-)
Bosch SHU53A06 UC/14 (FD 8211-)
Bosch SHU53E02 UC/14 (FD 8211-)
Bosch SHU53E05 UC/14 (FD 8211-)
Bosch SHU53E06 UC/14 (FD 8211-)
Whirlpool SHU55010 Dishwasher
Whirlpool SHU55040 Dishwasher
Whirlpool SHU55042 Dishwasher
Whirlpool SHU60020 Dishwasher
Bosch SHU66C02 UC/14 (FD 8211-)
Bosch SHU66C05 UC/14 (FD 8211-)
Bosch SHU66C06 UC/14 (FD 8211-)
Bosch SHU66C07 UC/14 (FD 8211-)
Bosch SHU66E02 UC/14 (FD 8211-)
Bosch SHU66E05 UC/14 (FD 8211-)
Bosch SHU66E06 UC/14 (FD 8211-)
Bosch SHU66E07 UC/14 (FD 8211-)
Bosch SHU6802 UC/06 (FD 7705-7912)
Bosch SHU6802 UC/11 (FD 8001-8003)
Bosch SHU6802 UC/12 (FD 8003-)
Bosch SHU6805 UC/06 (FD 7705-7912)
Bosch SHU6805 UC/11 (FD 8001-8003)
Bosch SHU6805 UC/12 (FD 8003-)
Bosch SHU6806 UC/06 (FD 7705-7912)
Bosch SHU6806 UC/11 (FD 8001-8003)
Bosch SHU6806 UC/12 (FD 8003-)
Whirlpool SHU70010 Dishwasher
Whirlpool SHU70041 Dishwasher
Whirlpool SHU70050 Dishwasher
Whirlpool SHU70051 Dishwasher
Whirlpool SHU70052 Dishwasher
Whirlpool SHU75010 Dishwasher
Whirlpool SHU75042 Dishwasher
Whirlpool SHU80010 Dishwasher
Whirlpool SHU80041 Dishwasher
Whirlpool SHU80042 Dishwasher
Bosch SHU8802 UC/12 (FD 8105-)
Bosch SHU8805 UC/12 (FD 8105-)
Bosch SHU8806 UC/12 (FD 8105-)
Bosch SHU8812 UC/12 (FD 8105-)
Bosch SHU8815 UC/12 (FD 8105-)
Bosch SHU8816 UC/12 (FD 8105-)
Whirlpool SHU90002 Dishwasher
Whirlpool SHU90041 Dishwasher
Whirlpool SHU90050 Dishwasher
Bosch SHU9902 UC/06
Bosch SHU9902 UC/06 (FD 7905-7912)
Whirlpool SHU99041 Dishwasher
Bosch SHU9905 UC/06
Bosch SHU9905 UC/06 (FD 7905-7912)
Whirlpool SHU99052 Dishwasher
Whirlpool SHU99053 Dishwasher
Bosch SHU9906 UC/06
Bosch SHU9906 UC/06 (FD 7905-7912)
Bosch SHU9912 UC/06
Bosch SHU9912 UC/06 (FD 7908-8002)
Bosch SHU9912 UC/11
Bosch SHU9912 UC/11 (FD 8002-8003)
Bosch SHU9912 UC/12
Bosch SHU9912 UC/12 (FD 8003-)
Bosch SHU9915 UC/06
Bosch SHU9915 UC/06 (FD 7908-8002)
Bosch SHU9915 UC/11
Bosch SHU9915 UC/11 (FD 8002-8003)
Bosch SHU9915 UC/12
Bosch SHU9915 UC/12 (FD 8003-)
Bosch SHU9916 UC/06
Bosch SHU9916 UC/06 (FD 7908-8002)
Bosch SHU9916 UC/11
Bosch SHU9916 UC/11 (FD 8002-8003)
Bosch SHU9916 UC/12
Bosch SHU9916 UC/12 (FD 8003-)
Bosch SHU9922 UC/12 (FD 8003-)
Bosch SHU9925 UC/12 (FD 8003-)
Bosch SHU9926 UC/12 (FD 8003-)
Bosch SHU9952 UC/12 (FD 8105 -)
Bosch SHU9955 UC/12 (FD 8105 -)
Bosch SHU9956 UC/12 (FD 8105 -)
Bosch SHV4303 UC/06
Bosch SHV4303 UC/06 (FD 7712-8002)
Bosch SHV4303 UC/11
Bosch SHV4303 UC/11 (FD 8002-8003)
Bosch SHV4303 UC/12
Bosch SHV4303 UC/12 (FD 8003-)
Bosch SHV46C03 UC/14 (FD 8211-)
Bosch SHV4803 UC/06
Bosch SHV4803 UC/06 (FD 7712-7812, 7905-7907)
Bosch SHV4803 UC/07
Bosch SHV4803 UC/07 (FD 7812-7905, 7907-8010)
Bosch SHV4803 UC/12
Bosch SHV66A03 UC/14 (FD 8301-)
Bosch SHV6803 UC/12 (FD 8105 -)
Bosch SHV99A03 UC/14 (FD 8212-)
Hoover SHWA2501A WASHER-TOP LOADING
Hoover SHWA2501W WASHER-TOP LOADING
Hoover SHWA2506A WASHER-TOP LOADING
Hoover SHWA2506AT WASHER-TOP LOADING
Hoover SHWA2506W WASHER-TOP LOADING
Hoover SHWA2506WT WASHER-TOP LOADING
Hoover SHWA2507V WASHER-TOP LOADING
Bosch SHX33A02 UC/14 (FD 8211-)
Bosch SHX33A05 UC/14 (FD 8211-)
Bosch SHX33A06 UC/14 (FD 8211-)
Bosch SHX43E02 UC/14 (FD 8211-)
Bosch SHX43E05 UC/14 (FD 8211-)
Bosch SHX43E06 UC/14 (FD 8211-)
Bosch SHX46A02 UC/14 (FD 8211-)
Bosch SHX46A05 UC/14 (FD 8211-)
Bosch SHX46A06 UC/14 (FD 8211-)
Bosch SHX46A07 UC/14 (FD 8211-)
Bosch SHX46B02 UC/14 (FD 8211-)
Bosch SHX46B05 UC/14 (FD 8211-)
Bosch SHX46B06 UC/14 (FD 8211-)
Bosch SHX46B07 UC/14 (FD 8211-)
Bosch SHX56B02 UC/14 (FD 8211-)
  #2 (permalink)
Old 03-29-2008, 03:20 PM
Junior Member
georgerdavis is on a distinguished road
Default
Kevin...The problem is a burnt heater circuit on the control board. If you're handy with soldering, you can solder the circuit. Otherwise, just replace the board.
  #3 (permalink)
Old 03-30-2008, 04:37 AM
Junior Member
Default
Thank you George, I appreciate your help. I do have a solddering iron, but where would I get another circuit?
  #4 (permalink)
Old 03-30-2008, 05:14 AM
Junior Member
Default
Kevin;
If you take the console off the machine, you'll see the control box on the right. It's usually a white plastic case. Disconnect the wiring, unhook the wires to the start switch and the green ground wire. You can lay the console on a padded surface, then gently release the black tabs holding the metal frame to the console to have access to the control module. Release the module from the metal frame, then you can snap open the case around the control board. If you lift out the board, you can turn it over and you'll see a blackened spot where the heater circuit bunrt out. Some guys have been successful just re-soldering that circuit on the board. It's worth a try. If , after doing that and you've reinstalled everything, the time still remains at 1 minute, you'll have to invest in a new control. Just enter the machine's model number on this site's search engine to get the right one. Good luck!
  #5 (permalink)
Old 03-30-2008, 06:29 AM
Junior Member
Default
Thanks George, I'm going to have at it!
You"re a great help, I'll let you know the results.
Kevin
  #6 (permalink)
Old 04-04-2008, 05:09 PM
Junior Member
Default
Received and installed a new control board today, dishwasher is fixed, thanks George!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Dishwasher Stuck on 2H SeattlePete Dishwasher Repair 37 03-23-2013 09:02 AM
Bosch dishwasher-starts on 2H gets stuck on 1 olijo Dishwasher Repair 6 01-17-2012 11:29 AM
Bosch dishwasher stuck at 8 min Reddrum Dishwasher Repair 0 02-02-2010 03:18 PM
Bosch Dishwasher On/Off Switch Stuck Martinlady Dishwasher Repair 0 10-10-2009 07:53 AM
Bosch Dishwasher Dial Stuck JJ2 Dishwasher Repair 0 08-06-2008 07:21 AM
