Discuss
Replacing water valve assembly on brand new Bosch
 in
Dishwasher Repair
I recently purchased a Bosch dishwasher, model SHE43MO6UC/48 and attempted to install it myself. I made the mistake of
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Replacing water valve assembly on brand new Bosch
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 03-26-2008, 03:56 PM
NickB NickB is offline
Junior Member
NickB is on a distinguished road
Exclamation Replacing water valve assembly on brand new Bosch
Model Number: SHE43MO6UC/48   Brand: Bosch   Age: Less than 1 year
I recently purchased a Bosch dishwasher, model SHE43MO6UC/48 and attempted to install it myself. I made the mistake of not using plumbing tape before putting the elbow on to the existing water valve assembly, and then when it tightened up facing the wrong direction, I cranked on it to get it pointing in the right direction. I then realized that I should never over tighten brass plumbing, especially with no threading tape on. Sure enough, this joint leaked. When attempting to remove the elbow, the entire existing brass piece rotated with it and I was unable to remove the elbow. I attempted to use plumbers epoxy to seal the joint, but the water still finds its way out very slowly. I then ordered the replacement water valve assembly from appliancepartspros.com (part # AP3783031 (425458)), and upon removing the existing assembly, I noticed that the current wires going to the factory assembly terminate in a small plastic box and the existing assembly has a small plastic receiving box atop the teal colored cylinder for this to click in to. The new replacement part mentioned above, does not have this receiving box, it just has 2 vertical metal posts with a single hole in the center of each extending from the top of the teal colored cylinder. It is not as easy as moving the plastic box from the existing assembly to the new one as they are not compatible. Do I have the wrong part or is it just slightly different than the factory part and I can make it work somehow. Please help. This is a brand new dishwasher that has never been run and I just made a really stupid mistake by over-tightening the elbow for the water supply hose and ended up in this mess. So far, I've yet to spend the $150 Sears would have charged to install it for me and I'm gaining all this experience, but it's getting to be quite a headache. Thank you.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-27-2008, 12:01 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Nick,
The model number you posted does not come up.
Verify and repost it, please.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 03-28-2008, 03:01 AM
Carson1214 Carson1214 is offline
Junior Member
Carson1214 is on a distinguished road
Default
Nick
You do have the wrong part the wire connection on the valve has been the Rast connection (little box) for over a year now. You need to order Part Number: AP4070550 (Bosch part # 607335)
Your model number is correct the model was new in March 07 I don't know why it isn't comming up here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing a Frigidaire glass cooktop assembly ajensenlsu Oven Repair (including Ranges and Cooktops) 3 06-28-2008 11:26 AM
Replacing Water Valve AP3192626 jonesware Refrigerator & Freezer Repair 7 04-09-2008 06:43 PM
Replacing panel control assembly dlm60d Oven Repair (including Ranges and Cooktops) 0 02-12-2008 07:13 AM
Bosch washer- leaking at pump assembly PBroadfoot Washer Repair 2 01-19-2008 07:57 AM
replacing outlet valve for ice maker stanleyn Refrigerator & Freezer Repair 1 12-17-2007 07:02 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
