Discuss
Dishwasher drain pump stays on continuously
 in
Dishwasher Repair
Drain pump stays on all the time. The filter is clean and when I pour clean water into the machine
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher drain pump stays on continuously
  #1 (permalink)
Old 03-26-2008, 03:10 PM
WilliamS WilliamS is offline
Junior Member
WilliamS is on a distinguished road
Default Dishwasher drain pump stays on continuously
Model Number: ASF645 model no. 911232112   Brand: Electrolux   Age: 5 - 10 years
Drain pump stays on all the time. The filter is clean and when I pour clean water into the machine it gets pumped out OK. The bottom of the dishwasher is dry. I checked the little float switch attached to a piece of foam and it seems to be working OK.
This started happening after an incident when the filter was clogged up at the end of a wash cycle. I cleaned the filter but now the drain pump still stays on all the time.
I tried turning the programmer dial manually but that doesn't help (the pump goes off but the wash cycle doesn't start)
Any ideas what the problem could be?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-26-2008, 03:28 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi William,
The model number you posted does not come up. It could be incorrect or this is not American model. Verify and repost it, please.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 03-27-2008, 09:50 AM
Junior Member
Default
Hi Gene,
thanks for your quick feedback on my posting.
Its a european model dishwasher Arthur Martin Electrolux type ASF645. The model number is 911232112 according to info from the sticker on the inside of the door.
Yesterday I dried out the floor of the dishwasher completely but that doesn't seem to fix it (the floor was a still a bit damp from the time the filter got blocked).
The microswitch attached to the block of foam at the base of the machine seems to click on and off OK when I lift the foam block up and down. So the safety shut off mechanism seems to be working normally (I didn't check this with a multimeter though)
When I switch on the machine for a wash cycle the programmer doesn't advance any further than the initial drain part of the cycle. If I force the program dial on by hand the drain pump goes off but the rest of the wash cycle doesn't start (i.e. the dishwasher does nothing at all).
  #4 (permalink)
Old 03-27-2008, 11:06 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi William,
Unfortunately most of European models designed very different compare to American and I can not find any reliable information on line. Maybe someone else on the forum can help you better.
__________________
  #5 (permalink)
Old 03-27-2008, 03:43 PM
Junior Member
Default
I forgot to mention that if I pour water into the machine, it discharges it without a problem, but the pump doesn't shut off.
  #6 (permalink)
Old 05-30-2008, 04:37 PM
Junior Member
Smile Fixed the dishwasher in the end
Got the dishwasher working in the end. The drain was blocked causing water to leak out into the base of the machine activating the drain pump AND the safety microswitch in the door also had failed (to open circuit). I cleaned the filter, dried out the bottom of the dishwasher and changed the door mechanism and the washer worked.
The clue the led me to find the broken door switch was that once the dishwasher base was dry the progam wouldn't start and no power was reaching the pressostat
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
nosiy drain pump puffinboy Washer Repair 3 02-19-2008 09:15 AM
Drain Pump keeps running WaltG Dishwasher Repair 1 02-08-2008 01:06 PM
Noisy drain pump HOMIE Dishwasher Repair 1 01-10-2008 08:58 PM
HE3T Drain Pump Jim Bo Washer Repair 1 12-29-2007 02:57 PM
Drain Pump loadster Dishwasher Repair 1 08-07-2007 07:35 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
