Discuss
Whirlpool dishwasher fuse
 in
Dishwasher Repair
I need to replace the control board of my Whirlpool dishwasher. There is a thermal fuse next to the control
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirlpool dishwasher fuse
  #1 (permalink)
Old 01-05-2010, 12:21 PM
Junior Member
joedavis1012 is on a distinguished road
Default Whirlpool dishwasher fuse
Model Number: DU920QWDQ3   Brand: Whirlpool   Age: More than 10 years
I need to replace the control board of my Whirlpool dishwasher. There is a thermal fuse next to the control board. There are two spring loaded breakers. One of the two has tripped. The other has not. Do I need to replace the fuse along with the control board ? Or do I replace the control board and just reset the breaker that tripped ?
Ads By Google
Related Models
Whirlpool DU920QWDQ3
Whirlpool DU920QWDQ4
Whirlpool DU920QWDQ5
Whirlpool DU920QWDQ6
Whirlpool DU925QWDB0
Whirlpool DU925QWDB2
Whirlpool DU925QWDB3
Whirlpool DU925QWDB4
Whirlpool DU925QWDB5
Whirlpool DU925QWDB6
Whirlpool DU925QWDQ0
Whirlpool DU925QWDQ2
Whirlpool DU925QWDQ3
Whirlpool DU925QWDQ4
Whirlpool DU925QWDQ5
Whirlpool DU925QWDQ6
Whirlpool DU925SCGB0
Whirlpool DU925SCGB1
Whirlpool DU925SCGB2
Whirlpool DU925SCGB3
Whirlpool DU925SCGQ0
Whirlpool DU925SCGQ1
Whirlpool DU925SCGQ2
Whirlpool DU925SCGQ3
Whirlpool DU925SCGZ1
Whirlpool DU925SCGZ2
Whirlpool DU925SCGZ3
Whirlpool DU927QWDB0
Whirlpool DU927QWDB1
Whirlpool DU927QWDQ0
Whirlpool DU927QWDQ1
Whirlpool DU927QWDZ0
Whirlpool DU927QWDZ1
Whirlpool DU929PFGB0
Whirlpool DU929PFGB1
Whirlpool DU929PFGB2
Whirlpool DU929PFGQ0
Whirlpool DU929PFGQ1
Whirlpool DU929PFGQ2
Whirlpool DU929QWDB0
Whirlpool DU929QWDB1
Whirlpool DU929QWDQ0
Whirlpool DU929QWDQ1
Whirlpool DU930PWKB0
Whirlpool DU930PWKQ0
Whirlpool DU930PWPB0 Undercounter Dishwasher
Whirlpool DU930PWPB1 Undercounter Dishwasher
Whirlpool DU930PWPB2 Undercounter Dishwasher
Whirlpool DU930PWPQ0 Undercounter Dishwasher
Whirlpool DU930PWPQ1 Undercounter Dishwasher
Whirlpool DU930PWPQ2 Undercounter Dishwasher
Whirlpool DU930PWPS0 Undercounter Dishwasher
Whirlpool DU930PWPS1 Undercounter Dishwasher
Whirlpool DU930PWPS2 Undercounter Dishwasher
Whirlpool DU930PWPT0 Undercounter Dishwasher
Whirlpool DU930PWPT1 Undercounter Dishwasher
Whirlpool DU930PWPT2 Undercounter Dishwasher
Whirlpool DU930PWSB0 Undercounter Dishwasher
Whirlpool DU930PWSQ0 Undercounter Dishwasher
Whirlpool DU930PWSS0 Undercounter Dishwasher
Whirlpool DU930PWST0 Undercounter Dishwasher
Whirlpool DU930QWDB0
Whirlpool DU930QWDB2
Whirlpool DU930QWDB3
Whirlpool DU930QWDB4
Whirlpool DU930QWDB5
Whirlpool DU930QWDB6
Whirlpool DU930QWDQ0
Whirlpool DU930QWDQ2
Whirlpool DU930QWDQ3
Whirlpool DU930QWDQ4
Whirlpool DU930QWDQ5
Whirlpool DU930QWDQ6
Whirlpool DU931SCGB0
Whirlpool DU931SCGB1
Whirlpool DU931SCGQ0
Whirlpool DU931SCGQ1
Whirlpool DU935QWDB0
Whirlpool DU935QWDB1
Whirlpool DU935QWDB5
Whirlpool DU935QWDB6
Whirlpool DU935QWDQ0
Whirlpool DU935QWDQ1
Whirlpool DU935QWDQ5
Whirlpool DU935QWDQ6
Whirlpool DU9400XB0
Whirlpool DU9400XB1
Whirlpool DU9400XT0
Whirlpool DU9400XT1
Whirlpool DU9400XT4
Whirlpool DU9400XY0
Whirlpool DU9400XY1
Whirlpool DU9400XY2
Whirlpool DU940PWKB0
Whirlpool DU940PWKB1
Whirlpool DU940PWKQ0
Whirlpool DU940PWKQ1
Whirlpool DU940PWKS1
Whirlpool DU940PWKT0
Whirlpool DU940PWKT1
Whirlpool DU940QWDB0
Whirlpool DU940QWDB2
Whirlpool DU940QWDB3
Whirlpool DU940QWDB4
Whirlpool DU940QWDB5
Whirlpool DU940QWDB6
Whirlpool DU940QWDQ0
Whirlpool DU940QWDQ2
Whirlpool DU940QWDQ3
Whirlpool DU940QWDQ4
Whirlpool DU940QWDQ5
Whirlpool DU940QWDQ6
Whirlpool DU940QWDZ0
Whirlpool DU940QWDZ2
Whirlpool DU940QWDZ3
Whirlpool DU940QWDZ4
Whirlpool DU940QWDZ5
Whirlpool DU940QWDZ6
Whirlpool DU941PWKB0
Whirlpool DU941PWKB1
  #2 (permalink)
Old 01-05-2010, 12:35 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL DU920QWDQ3 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/w...%203379064.pdf
Why? What are the symptoms? What have you done to troubleshoot it?
This is where you loose me. Are you referring to the door latch switches, Item 11 in Section 1?
In order to know what to replace you have to check the fuse to see if it is blown. It could be that it is all that is wrong with the unit. If it is the fuse the new wiring harness also has to be used. See Item 4 in Section 1.
Again am lost here as I do not see circuit breakers in either the parts or the wiring diagram. If it is the switches, both should close when the door is latched.
__________________
  #3 (permalink)
Old 01-05-2010, 04:56 PM
Junior Member
Default Reply to Denman
Sorry, I mistook the dual motor (3374501, item 17) for the thermal fuse (3376359, item 4). Ignore everything I said about the thermal fuse. The reason I need to replace the control board is because the dishwasher failed to turn on. So I had a repairman come out and look at it. He said that the control board needed to be replaced. So I decided to do it myself. I took the door apart to expose the control board and found that there was an area of black residue near the thermal fuse. So it appears that the thermal fuse definitely needs to be replaced. It would seem that the control board also needs to be replaced, otherwise, why would the fuse blow ? The dual motor is the device that has two spring loaded latches. One latch is released and won't reset in the "in" position. The other latch is set in the "in" position. Is that a normal condition for the dual motor latches ? Are those latches actually circuit breakers ? By the way, I do own a volt/ohm/amp meter. Let me know what measurements you would like me to make and I will do it.
  #4 (permalink)
Old 01-05-2010, 05:48 PM
Senior Expert
APP Volunteer
Default
Here is a manual which may be useful
https://secured.whirlpool.com/Servic...E/4322451L.pdf
If the repairman did not remove the inner door panel then he was just guessing.
The fuse can blow because of excessive current but it is designed to blow because of high temperatures. If the residue near the fuse is soot then it may have blown due to high current. This could be a shorted device or a blown board.
Check it with a meter it should be 0 ohms.
Sometimes they just blow as you can see the replacement is a kit to reduce the fuses doing this. Also could be a device has shorted.
Check the various devices to make sure they have resistance basically you are trying to find out if anything has shorted. Note always remove at least one wire from anything you are measuring for ohms. This ensures that you do not read an alternate/parallel circuit path.
Not sure where they should be at rest, check the manual. They are wax motors. Basically this is a plunger in a cylinder filled with wax. You will see on the wiring diagram that each one has a small heater in it. When this heater is turned on the wax melts, expands and pushes the plunger out. Remove power to the heater and as the wax solidifies the plunger is retracted. Sort of like a slow acting solenoid. They run the rinse aid and detergent.
This is what I would do but do not know what experience you have so am not recommending it.
I would check the fuse.
If blown I would wire in a standard 10 amp fuse.
And give it a try.
If it fires up and runs a cycle then you know that it is probably just the fuse that is blown.
Do not run the unit like this, it is just to check the system.
I would then order and replace the fuse ASAP as it is a critical safety device for both temperature and current.
If the 10 amp blows then check the various devices for resistance.
If all are OK then it is probably the board that is shot.
At close to $170.00, I do not know if it is worth putting that many dollars into this fairly old machine unless it is in excellent condition.
__________________
  #5 (permalink)
Old 01-05-2010, 09:15 PM
Junior Member
Thank you for your followup. I will try everything you suggest. One question. When you say "If the 10 amp blows then check the various devices for resistance", can you tell me which specific devices I should check ? Thanks.
  #6 (permalink)
Old 01-06-2010, 02:49 AM
Senior Expert
APP Volunteer
Default
I would check both wax motors, pump motor windings and the fill valve.
Also visually check the wiring where it goes from the door to under the unit.
__________________
  #7 (permalink)
Old 01-06-2010, 10:44 PM
Junior Member
I have measured the resistance across the thermal fuse and it is zero. I guess this means that the fuse has not blown ? I also measured the resistance across each of the two dual motors. They were each about 4000 ohms. The repairman already checked the motor and fill valve and said they were Ok. So it appears that everything else seems to be working. I guess this leaves the control board as the problem ?
  #8 (permalink)
Old 01-07-2010, 02:34 AM
Senior Expert
APP Volunteer
Default
Have you checked both door latch switches to make sure that they both close and when closed they are at 0 ohms.
You could also close them and then check that you have 120 volts between P8 and P7 on the board.
If you do have the correct voltage here then I would put the board at the top of the list.
__________________
  #9 (permalink)
Old 01-08-2010, 12:37 PM
Junior Member
I measured the resistance of each switch in the closed position and got zero ohms for both of them. I then measured the voltage between P7 and P8 and got 120 volts. Is the next step to replace the control board ? Our dishwasher is in excellent condition. We have a water softener and always clean food off of the plates before putting them in the dishwasher. So it is pretty pristene for being 13 years old.
  #10 (permalink)
Old 01-08-2010, 12:48 PM
Senior Expert
APP Volunteer
Default
Yes that would be what I would do as it is getting power and will not fire up.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool dryer thermal fuse kirks Dryer Repair 1 02-03-2010 03:01 AM
fuse location in dishwasher dezsp52 Dishwasher Repair 1 10-23-2009 06:51 AM
Whirlpool dryer fuse keeps blowing Venus1974tn Dryer Repair 1 10-22-2009 05:57 PM
Whirlpool Fuse johnfolk Microwave Repair 2 04-23-2009 08:08 PM
whirlpool fuse replacement rose63 Oven Repair (including Ranges and Cooktops) 0 07-25-2008 06:22 PM
