fj4x4
#1 Posted : Tuesday, January 5, 2010 10:04:00 AM(UTC)
fj4x4
Don't heat the water or dry the dishes or clean very well.
Also has extra long cycle times.
#2 Posted : Wednesday, January 6, 2010 2:54:01 AM(UTC)
Replacement parts for WHIRLPOOL KUDR01TJWH1 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/TechSheets_11_17_09/Tech%20Sheet%20-%208533399.pdf
Since the unit does complete a cycle and you did not mention extra long cycle times I would suspect the thermistor. Check it with a meter.
The problem is that this does not explain why the dishes are not drying.
Could be that you have 2 problems.
Could also be the heater itself or the high limit thermostat but as mentioned above I would have thought you would see extra long cycle times.
Check them with a meter.
fj4x4
#3 Posted : Thursday, January 7, 2010 4:44:09 AM(UTC)
fj4x4
It does have extra long cycle times also.
#4 Posted : Friday, January 8, 2010 3:42:14 AM(UTC)
Then it sounds like there is a problem in the heater circuit.
This should not be difficult to troubleshoot with a meter.
fj4x4
#5 Posted : Friday, January 8, 2010 5:04:38 AM(UTC)
fj4x4
O.K. , Thanks Denman.
dish washer runs with doo open (Dishwasher Repair)
by Guest 4/17/2022 8:59:58 PM(UTC)
Dish washer not cleaning dishes KDTE204EPA1 (Dishwasher Repair)
by Guest 12/15/2021 7:24:01 AM(UTC)
correct orientation of plugs on ASKO D3122 anti flood microswitch. dish washer ? (Dishwasher Repair)
by turbo1600 8/20/2020 8:16:40 PM(UTC)
Whirlpool dish washer WDF110PABB2 Filling but not washing. (Dishwasher Repair)
by KG4MXV 6/15/2018 2:57:20 PM(UTC)
Kitchenaid dish washer leaking from below (Dishwasher Repair)
by chrysrobyn 12/19/2016 6:33:56 AM(UTC)
Dish washer stopped and want finish, all lights off (Dishwasher Repair)
by b.alford002@comcast.net 8/30/2015 11:17:11 AM(UTC)
How to replace motor bearings on Kitchen Aid KUDSO1FLSS1 dish washer (Dishwasher Repair)
by rajfixplumming 3/1/2014 10:33:52 AM(UTC)
Dish washer stops 14 Min in to cycle (Dishwasher Repair)
by Wayne_44 2/6/2014 4:55:37 PM(UTC)
Dish washer no lights on panel stopped mid cycle (Dishwasher Repair)
by 56Gomer 8/18/2013 6:34:28 AM(UTC)
by poloman 8/5/2013 9:38:22 AM(UTC)
by poloman 8/5/2013 9:34:27 AM(UTC)
Dish Washer (Dishwasher Repair)
by jobronie 7/25/2013 3:42:51 PM(UTC)
by everettwayne 6/19/2013 8:19:55 AM(UTC)
Dish washer won't dispense water. (Dishwasher Repair)
by Tom Loszchuk 4/2/2013 5:52:22 PM(UTC)
GE Dish Washer Stops midcycle (Dishwasher Repair)
by mwpresnell 2/8/2013 8:41:24 AM(UTC)
