Discuss
Dishwasher lower are not spraying or moving
 in
Dishwasher Repair
The lower washer arm is loose and is not spraying or moving during cycle. Please advise. Thank you!! Ads By
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher lower are not spraying or moving
  #1 (permalink)
Old 01-04-2010, 08:30 AM
Junior Member
Patricia Ratliff is on a distinguished road
Default Dishwasher lower are not spraying or moving
Model Number: DU8900XT   Brand: Whirlpool   Age: More than 10 years
Ads By Google
Related Models
Whirlpool DU8900XT0
Whirlpool DU8900XT1
Whirlpool DU8900XT2
Whirlpool DU8900XT3
Whirlpool DU8900XT4
Whirlpool DU8900XT5
Whirlpool DU8900XT6
Whirlpool DU8900XY0
Whirlpool DU8900XY1
Whirlpool DU8900XY2
Whirlpool DU8903XL0
Whirlpool DU890DWGQ0
Whirlpool DU890DWGQ1
Whirlpool DU890DWGQ2
Whirlpool DU890DWGU2
Whirlpool DU890DWGX0
Whirlpool DU890DWGX1
Whirlpool DU890DWGZ0
Whirlpool DU890DWGZ1
Whirlpool DU890DWGZ2
Whirlpool DU890SWKQ0
Whirlpool DU890SWKT0
Whirlpool DU890SWKU0
Whirlpool DU890SWLQ0 Undercounter Dishwasher
Whirlpool DU890SWLTO Undercounter Dishwasher
Whirlpool DU890SWLU0 Undercounter Dishwasher
Whirlpool DU8920XX0
Whirlpool DU8950XB0
Whirlpool DU8950XB1
Whirlpool DU8950XT0
Whirlpool DU8950XT1
Whirlpool DU8950XT2
Whirlpool DU8950XT3
Whirlpool DU8950XX0
Whirlpool DU8950XY0
Whirlpool DU8950XY1
Whirlpool DU8950XY2
Whirlpool DU895SWPB0 Undercounter Dishwasher
Whirlpool DU895SWPQ0 Undercounter Dishwasher
Whirlpool DU895SWPS0 Undercounter Dishwasher
Whirlpool DU895SWPT0 Undercounter Dishwasher
Whirlpool DU895SWPU0 Undercounter Dishwasher
Whirlpool DU8960XB0
Whirlpool DU8960XB1
Whirlpool DU8960XY0
Whirlpool DU8960XY1
Magic Chef DU8J Dishwasher - Undercounter
Whirlpool DU9000XR0
Whirlpool DU9000XR1
Whirlpool DU9000XR2
Whirlpool DU9000XR3
Whirlpool DU9000XR4
Whirlpool DU9000XR5
Whirlpool DU9000XR6
Whirlpool DU9000XR7
Whirlpool DU9000XR8
Whirlpool DU9000XR9
Whirlpool DU900PCDB0
Whirlpool DU900PCDB2
Whirlpool DU900PCDB3
Whirlpool DU900PCDB4
Whirlpool DU900PCDB5
Whirlpool DU900PCDB6
Whirlpool DU900PCDQ0
Whirlpool DU900PCDQ2
Whirlpool DU900PCDQ3
Whirlpool DU900PCDQ4
Whirlpool DU900PCDQ5
Whirlpool DU900PCDQ6
Whirlpool DU900PCDZ0
Whirlpool DU900PCDZ2
Whirlpool DU900PCDZ3
Whirlpool DU900PCDZ4
Whirlpool DU900PCDZ5
Whirlpool DU900PCDZ6
Whirlpool DU900PWKB0
Whirlpool DU900PWKQ0
Whirlpool DU900PWKT0
Amana DU9010B Dishwasher - Undercounter
Amana DU9010W Dishwasher - Undercounter
Whirlpool DU909PWKB0 Undercounter Dishwasher
Whirlpool DU909PWKQ0 Undercounter Dishwasher
Whirlpool DU909PWKT0 Undercounter Dishwasher
Magic Chef DU90A-01 Dishwasher - Undercounter
Magic Chef DU90A-02 Dishwasher - Undercounter
Whirlpool DU9100XT0
Whirlpool DU9100XT1
Whirlpool DU9100XT4
Whirlpool DU910PFGB0
Whirlpool DU910PFGB1
Whirlpool DU910PFGQ0
Whirlpool DU910PFGQ1
Whirlpool DU910PFGZ0
Whirlpool DU910PFGZ1
Whirlpool DU910PWKB0
Whirlpool DU910PWKQ0
Whirlpool DU911PCDB0
Whirlpool DU911PCDQ0
Whirlpool DU911PWKB0
Whirlpool DU911PWKQ0
Whirlpool DU912PFGB0
Whirlpool DU912PFGB1
Whirlpool DU912PFGB2
Whirlpool DU912PFGQ0
Whirlpool DU912PFGQ1
Whirlpool DU912PFGQ2
Whirlpool DU912PFGT2
Whirlpool DU912PFGZ0
Whirlpool DU912PFGZ1
Whirlpool DU912PFGZ2
  #2 (permalink)
Old 01-05-2010, 05:40 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for DU8900XT models | AppliancePartsPros.com
Here is a manual the pump should be close to yours
https://secured.whirlpool.com/Servic...E/4322451L.pdf
All spray arms are a little loose so it is hard to say if this is a problem. You will have to remove it and check it and it's cap for signs of wear.
Also check that the holes are clean.
You did not say if the upper wash arm rotates OK.
If not you may have a low water level problem or dirty pump filters or a pump problem.
__________________
  #3 (permalink)
Old 01-05-2010, 11:03 AM
Junior Member
Wink Whirlpool dishwasher DU8900XT-5
Quote:
Originally Posted by denman View Post
I am a female and am not sure what I am doing, but did determine that both upper and lower washer arms are spraying. The problem is that the lower arm is not turning during the cycle. I took the lower arm off and it was not stopped up. When I took the part that holds the lower arm on and put it back on and tightened it and then manually tried to push the washer arm around, it was like stopped and would not move, When I loosened the part holding it on, the holder and arm come off. Help!!
  #4 (permalink)
Old 01-05-2010, 06:00 PM
Senior Expert
APP Volunteer
Default
We are all in that position at sometime about everything.
Unfortunately I cannot be of much help without being there and seeing the parts.
Perhaps if you look at the parts breakdown you can figure it out. Note that often if you click on the picture of the part a new page will open with more views of the part which you can expand and look at.
If all else fails get a friend to look at it with you often two heads are better than one. Does sound like something has worn out or stripped.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Lower Washer Arm Not turning or spraying Patricia Ratliff Dishwasher Repair 0 01-02-2010 05:00 AM
lower spray arm not moving wor Dishwasher Repair 0 06-10-2009 12:30 PM
GE Dishwasher not spraying or draining pjones Dishwasher Repair 1 07-27-2008 09:20 PM
water not spraying from the lower and upper arm, jamesg Dishwasher Repair 3 06-25-2008 09:41 AM
water not spraying from the lower and upper arm jamesg Dishwasher Repair 0 06-20-2008 04:33 PM
