Discuss
Bosch Dishwasher - Will not fill with water at start of cycle
 in
Dishwasher Repair
I have a very unusual problem with my Bosch Dishwasher Model SHU43C02UC. It will not fill with water when you
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch Dishwasher - Will not fill with water at start of cycle
  #1 (permalink)
Old 01-02-2010, 02:19 PM
Junior Member
xned is on a distinguished road
Default Bosch Dishwasher - Will not fill with water at start of cycle
Model Number: SHU43C02UC   Brand: Bosch   Age: 5 - 10 years
It will not fill with water when you first start the wash cycle (does not fill on any of the cycles, Power Scrub Plus, Regular Wash, Quick Wash or Rinse and Hold)
If you manually fill it then the cycle will complete normally. It empties the wash water and fills with rinse water successfully.
I have tried searching the internet for troubleshooting advice with limited success.
I did find a way to put this model into a self test mode by pressing the regular wash and rinse and hold buttons at the same time. http://www.applianceaid.com/boschDW.html
The instructions were not specifically for the same model as mine but were for SHU4322 & SHU4326 models. When I initiated this test on my machine it filled and washed for quite a long time. As I was not sure what how long this test should take I left if for over an hour at which time the display indicated 0 however the lights above the two buttons used to initiate the test continued to flash. According to the write up at the end of the test an indication of 0 means no faults were detected.
I found the troubleshooting manual for Bosch Dishwashers listed on this site but once again it didn’t specifically reference my model, or any model that required the same buttons to be pressed to initiate the self test.
Questions:
1. Is anyone familiar with testing this particular model? How long should the test take? What indicates a successful test?
2. Any ideas on what might cause this issue? I’m thinking that it must be something with the control board as all the other components seem to be working.
Ads By Google
Related Models
Bosch SHU43C05 UC/14 (FD 8211-)
Bosch SHU43C06 UC/14 (FD 8211-)
Bosch SHU43C07 UC/14 (FD 8211-)
Bosch SHU43E02 UC/14 (FD 8211-)
Bosch SHU43E05 UC/14 (FD 8211-)
Bosch SHU43E06 UC/14 (FD 8211-)
Bosch SHU43E07 UC/14 (FD 8211-)
Whirlpool SHU45010
Whirlpool SHU45020
Whirlpool SHU50000
Whirlpool SHU50001
Whirlpool SHU50002
Whirlpool SHU50010
Whirlpool SHU50040
Whirlpool SHU50041
Whirlpool SHU50043
Bosch SHU5302 UC/06 (FD 7705-7912)
Bosch SHU5302 UC/11 (FD 8001-8003)
Bosch SHU5302 UC/12 (FD 8003-)
Bosch SHU5304 UC/06 (FD 7705-7912)
Bosch SHU5304 UC/11 (FD 8001-8003)
Bosch SHU5304 UC/12 (FD 8003-)
Bosch SHU5305 UC/06 (FD 7705-7912)
Bosch SHU5305 UC/11 (FD 8001-8003)
Bosch SHU5305 UC/12 (FD 8003-)
Bosch SHU5306 UC/06 (FD 7705-7912)
Bosch SHU5306 UC/11 (FD 8001-8003)
Bosch SHU5306 UC/12 (FD 8003-)
Bosch SHU5307 UC/12 (FD 8003-)
Bosch SHU5312 UC/06
Bosch SHU5312 UC/11
Bosch SHU5312 UC/12
Bosch SHU5314 UC/06
Bosch SHU5314 UC/11
Bosch SHU5314 UC/12
Bosch SHU5315 UC/06
Bosch SHU5315 UC/06 (FD 7705-7912)
Bosch SHU5315 UC/11
Bosch SHU5315 UC/11 (FD 8001-8003)
Bosch SHU5315 UC/12
Bosch SHU5315 UC/12 (FD 8003-)
Bosch SHU5316 UC/06
Bosch SHU5316 UC/11
Bosch SHU5316 UC/12
Bosch SHU5317 UC/12
Bosch SHU53A02 UC/14 (FD 8211-)
Bosch SHU53A05 UC/14 (FD 8211-)
Bosch SHU53A06 UC/14 (FD 8211-)
Bosch SHU53E02 UC/14 (FD 8211-)
Bosch SHU53E05 UC/14 (FD 8211-)
Bosch SHU53E06 UC/14 (FD 8211-)
Whirlpool SHU55000
Whirlpool SHU55010
Whirlpool SHU55040
Whirlpool SHU55041
Whirlpool SHU55042
Whirlpool SHU60010
Whirlpool SHU60011
Whirlpool SHU60020
Bosch SHU66C02 UC/14 (FD 8211-)
Bosch SHU66C05 UC/14 (FD 8211-)
Bosch SHU66C06 UC/14 (FD 8211-)
Bosch SHU66C07 UC/14 (FD 8211-)
Bosch SHU66E02 UC/14 (FD 8211-)
Bosch SHU66E05 UC/14 (FD 8211-)
Bosch SHU66E06 UC/14 (FD 8211-)
Bosch SHU66E07 UC/14 (FD 8211-)
Bosch SHU6802 UC/06 (FD 7705-7912)
Bosch SHU6802 UC/11 (FD 8001-8003)
Bosch SHU6802 UC/12 (FD 8003-)
Bosch SHU6805 UC/06 (FD 7705-7912)
Bosch SHU6805 UC/11 (FD 8001-8003)
Bosch SHU6805 UC/12 (FD 8003-)
Bosch SHU6806 UC/06 (FD 7705-7912)
Bosch SHU6806 UC/11 (FD 8001-8003)
Bosch SHU6806 UC/12 (FD 8003-)
Whirlpool SHU70000
Whirlpool SHU70001
Whirlpool SHU70010
Whirlpool SHU70040
Whirlpool SHU70041
Whirlpool SHU70050
Whirlpool SHU70051
Whirlpool SHU70052
Whirlpool SHU75000
Whirlpool SHU75010
Whirlpool SHU75040
Whirlpool SHU75042
Whirlpool SHU80000
Whirlpool SHU80001
Whirlpool SHU80010
Whirlpool SHU80040
Whirlpool SHU80041
Whirlpool SHU80042
Bosch SHU8802 UC/12 (FD 8105-)
Bosch SHU8805 UC/12 (FD 8105-)
Bosch SHU8806 UC/12 (FD 8105-)
Bosch SHU8812 UC/12 (FD 8105-)
Bosch SHU8815 UC/12 (FD 8105-)
Bosch SHU8816 UC/12 (FD 8105-)
Whirlpool SHU90000
Whirlpool SHU90001
Whirlpool SHU90002
Whirlpool SHU90010
Whirlpool SHU90040
Whirlpool SHU90041
Whirlpool SHU90050
Whirlpool SHU99000
Whirlpool SHU99001
Bosch SHU9902 UC/06
Bosch SHU9902 UC/06 (FD 7905-7912)
Whirlpool SHU99040
Whirlpool SHU99041
Bosch SHU9905 UC/06
Bosch SHU9905 UC/06 (FD 7905-7912)
Whirlpool SHU99050
Whirlpool SHU99052
Whirlpool SHU99053
Bosch SHU9906 UC/06
Bosch SHU9906 UC/06 (FD 7905-7912)
  #2 (permalink)
Old 01-02-2010, 07:05 PM
Junior Member
Default
Quote:
On second look I did find instructions for my model in the troubleshooting manual.
bosch dishwasher troubleshoot manual
I now have a better understanding of the self test.
I don't know how but it seems to be working again. All I did was to manually fill it with water, add a cup full of vinegar and run it through a Regular Wash Cycle. Now it seems to work normally.
  #3 (permalink)
Old 03-22-2010, 11:23 AM
Junior Member
clareb is on a distinguished road
Default Bosch dishwasher won't fill - troubleshoot
Thanks for the great info.
I had a similar problem with the Bosch SHU3036: the motor would run for as long as the dishwasher was turned on (>16 hr), but no water would go into the dishwashwer.
I manually filled the dishwasher with water, then started a regular wash cycle. The dishwashwer is now running.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch dishwasher Won't fill with water SHD_VA Dishwasher Repair 0 02-08-2010 08:13 AM
Bosch Dishwasher Will Not fill with water drskinner Dishwasher Repair 1 10-06-2009 09:35 AM
bosch dishwasher will not fill water loas Dishwasher Repair 1 10-06-2009 09:31 AM
Dishwasher won't fill w/ water except during rinse cycle rocklorrie Dishwasher Repair 0 08-07-2009 10:41 PM
bosch dishwasher won't complete cycle dumped water on floor jimkaren Dishwasher Repair 2 12-01-2008 09:38 PM
