Discuss
Kenmore ultrawash quiet guard 4
 in
Dishwasher Repair
The top rack on my kenmore is not washing. The dishes get wet however it appears the upper arm is
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kenmore ultrawash quiet guard 4
  #1 (permalink)
Old 01-02-2010, 09:24 AM
Junior Member
jgearman is on a distinguished road
Default Kenmore ultrawash quiet guard 4
Brand: Kitchen Aid   Age: 1 - 5 years
The top rack on my kenmore is not washing. The dishes get wet however it appears the upper arm is not spraying or spinning.
Ads By Google
  #2 (permalink)
Old 01-02-2010, 09:46 AM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Try running a cycle without dishes, using Dishwasher Magic. Also, make sure you're getting at least 115 degree water.
  #3 (permalink)
Old 01-02-2010, 11:48 AM
Junior Member
NigelL is on a distinguished road
Default Possible solution
I had the same thing happen to me. The answer was to clean out the trap in the bottom of the washer. This involved removing the lower spray arm, then taking off the housing, revealing the input to the pump. I discovered some large beans (think red beans) which were plugging the water intake. Using my shop vac (after removing the dust bag) I sucked out everything, reassembled the washer, and everything works fine.
I NOW (duh) rinse off the "larger bits" before putting plates into the washer.
Oh, I also checked and cleaned the upper rinse arm (the end ports were a bit plugged with muck). Again the shop vac and air compressor handled that nicely.
  #4 (permalink)
Old 09-23-2010, 10:36 AM
Junior Member
paulmark is on a distinguished road
It could be that the unused hole in the stand pipe is not being covered properly with that little flapper valve cover. I believe that washer has a two level upper rack adjustment, and when you slide the rack in, it goes into the proper hole, while the other hole is sealed off with the little flapper valve
  #5 (permalink)
Old 04-06-2011, 10:56 PM
Junior Member
bleong is on a distinguished road
Smile Top Sprayer Not Working.
This worked for me. Cleaning out the trap help increase the water flow to the top sprayer.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore ultra wash quiet guard johnabayer Dishwasher Repair 0 12-06-2009 09:09 PM
Noisy Quiet Guard purplejj Dishwasher Repair 0 07-21-2009 03:33 PM
Kenmore Quiet Guard 3 Dishwasher blinking start light Roland99 Dishwasher Repair 2 04-10-2009 02:44 PM
Noisy Kenmore Ultra Wash Quiet Guard 4 bosstone75 Dishwasher Repair 2 02-05-2009 05:13 PM
kenmore diswasher quiet guard LOUD, won't spin, keeps comming undone ckhelga Dishwasher Repair 0 12-06-2007 11:16 AM
