Apparently my bottom spray arm was not spinning. I removed the pop-up and spray arm by simply unscrewing and cleaned them. However, when I screwed everything back together it's too high and can't move because the bottom rack obstructs it. Part #22 spins OK. could there be something under it? If so, How do I get to it?
