Discuss
Bosch shu5314uc/06 long cycles
 in
Dishwasher Repair
I have a problem and from reading this board it can be one of 4 things. It comes up with
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch shu5314uc/06 long cycles
  #1 (permalink)
Old 03-24-2008, 06:23 AM
Junior Member
ddahlgren is on a distinguished road
Default Bosch shu5314uc/06 long cycles
Brand: Bosch   Age: 5 - 10 years
It comes up with a heater failure on the test program and long cycle times as well.
My local dealer got me a copy of the wiring diagram and from it I think the control activates a relay that puts line current on terminal l2.7-2 a large red wire that goes in series to the high limit, heater and flow switch to the neutral wire in the junction box. I am assuming that the machine will run with this wire disconnected from the control and if so can I put an ohm meter on it to see if there is continuity or a very low ohms reading when the machine is running to the neutral wire. Looking at the diagram the flow switch is normally open and closes when the pump is running and putting water thru the heater. I am thinking this test would eliminate 3 of the 4 components all at the same time, the high limit, heater and flow switch. I could also check for voltage at the terminal on the control board as well. I am well versed in wiring and electrical safety so understand the dangers in testing live circuits and quite comfortable in doing this. What I am trying to avoid is buying a control on speculation and pulling the machine out from under the cabinet to check the individual parts if it is not necesary. Any advise you might have to offer would be appeciated.
Dave
  #2 (permalink)
Old 03-24-2008, 05:56 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Dave,
Most likely you can test all of these parts form the front of the dishwasher.
For more accurate advise we need the complete model number of the dishwasher.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 03-25-2008, 04:09 AM
Junior Member
Default Model #
As it says in the title
Bosch SHU5314UC/06
under than it has
FD7709 25 0036
Dave
  #4 (permalink)
Old 03-25-2008, 02:27 PM
Junior Member
Default OK for laughs
Ran it with the cover for the dor off and came up with a zero no errors and now washing running way too long again with the door cover off..
Dave
  #5 (permalink)
Old 03-30-2008, 12:07 PM
Junior Member
Default
Quote:
Dave
OK finally got a chance to put a voltmeter on the control with it running. Started out at 120 volts and after the pump started went to 1 volt AC inthe circuit going to the heater and flow sensor. In my mind one of 2 things happened and do correct me if I am wrong.. Either the control can not provide enough current bad relay bad board etc though the board looks pristeen. Or the heater is shorted and draws that much current but that is very hard to believe I would have thought if would have poped a breaker. s a side note the Dw is on a GFI with the disposal but the disposal works just fine..I will hope for a reply to this or a suggestion as to what to buy to replace it..
Dave
  #6 (permalink)
Old 03-31-2008, 12:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Dave,
Were you able to check for continuity across the Red wire l2.7-2 and neutral (the Red wire disconnected form the control module) while the circulation pump was running with water in the dishwasher?
If there is nothing wrong (reading is about 11 Ohms) then the problem is a bad control module. No doubt about it.
If the circuit is open then you have to remove the dishwasher and check every part separate: the heater, the water flow switch, the NTC (temperature sensor) and the hi-limit thermostat.
Most likely the problem is a bad control module, especially it was most common problem for many years.
- The part number for the control module is AP2802870
__________________
  #7 (permalink)
Old 03-31-2008, 12:18 PM
Junior Member
Default
Quote:
Originally Posted by Gene View Post
Hi Dave,
I resoldered every joint in sight and scrubed the contacts with a pencil eraser it is actually just ran 2 loads ahead of the displyed time needed..
So as you say the control no doubt but the length of of the repair working is the next question..
Dave
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher cycles running too long Patricia Ratliff Dishwasher Repair 3 02-08-2010 08:03 AM
Kenmore Ultra Wash Dishwasher - Cycles running too long mrmichaeljmoore Dishwasher Repair 1 11-02-2009 02:39 AM
Bosch no heat and long cycles dsm1212 Dishwasher Repair 1 09-12-2009 08:17 AM
Dishwasher does not heat water - cycles too long shishilla2002@yahoo.com Dishwasher Repair 0 08-10-2009 11:13 AM
Dryer elements cycle off and on making long drying cycles showmewarrior Dryer Repair 1 04-19-2009 12:39 PM
