Discuss
Replaced Chopper - Is Pump OK?
 in
Dishwasher Repair
I replaced a broken chopper assembly (the victim of a small pit), but want to verify that the pump is
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Replaced Chopper - Is Pump OK?
  #1 (permalink)
Old 03-22-2008, 09:32 AM
crtwood crtwood is offline
Junior Member
crtwood is on a distinguished road
Default Replaced Chopper - Is Pump OK?
Model Number: 665.16912001   Brand: Kenmore   Age: 1 - 5 years
I replaced a broken chopper assembly (the victim of a small pit), but want to verify that the pump is OK before putting it all back together. It seems to turn with resistance and makes a bit of plastic-on-plastic rubbing noise, but I can't tell if the resistance is from the impeller or just back-winding the motor.
Before repairing the chopper, it seemed to drain fine (indicating that the pump/motor was working), but it also sprayed food particles all over the top shelf. Any tips for checking the pump? Thanks in advance.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-22-2008, 04:34 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Carefully look at the white end of the chopper that engages the motor impeller, if worn, replace the motor impeller also. Also, replace the black rubber check valve next to the chopper in the bottom of the pump housing.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
sock stuck in water pump... do i need a new pump? volcompunker82 Washer Repair 0 03-08-2008 08:20 PM
Chopper Assembly protector/cover stuck? skip Dishwasher Repair 5 01-27-2008 05:06 AM
Replaced keypad, Meomaxy Oven Repair (including Ranges and Cooktops) 1 01-13-2008 12:38 AM
Replaced timer, now what? rollo1960 Washer Repair 2 12-01-2007 07:37 AM
replaced latch assy- now won't run Rick P Dishwasher Repair 1 10-19-2007 03:51 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
