Discuss
Countdown Display INOP, Washer cycles normally
 in
Dishwasher Repair
Hello, I recently ordered from AppliancePartsPros.com a control module for my Bosch SHU9956 UC. The original control module was
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Countdown Display INOP, Washer cycles normally
  #1 (permalink)
Old 08-20-2007, 10:03 PM
Julia Julia is offline
Junior Member
Julia is on a distinguished road
Post Countdown Display INOP, Washer cycles normally
Model Number: SHU9956/14 UC   Brand: Bosch   Age: 5 - 10 years
Hello, I recently ordered from AppliancePartsPros.com a control module for my Bosch SHU9956 UC. The original control module was damaged due to a stupid mistake I installed the new control module and the countdown display does not light up... However, the dishwasher runs through its program that is selected (by guess, because the selector button lights don't come on and the countdown timer is blank e.g. off) and the machine appears to perform all cycles normally The lights on the front (wash, dry , clean) come on in sequence as the machine goes through its cycles.
If I put the dishwasher into a test mode by pressing the "regular wash" and "quick wash" buttons simultaneously, the countdown display lights up with the number "22". The display goes blank when I release these two buttons. Pushing "delay start" button causes the countdown display to show "18H". Push the "Delicate Wash" button causes the buzzer to sound, the number "188" to display and the "*" to display. Pressing the "regular wash" and "quick wash" buttons again simultaneously causes the display to show "1" and begins the cycle test where the machine drains, fills, washes and then drains. This total cycle time is about 23 minutes, most of which is spent heating the water. At the end of the full test the countdown display shows a fault code of "1", the "delay start" button is flashing and the the "regular wash" and quick wash" lights are flashing. Can you help me understand why the control module will not display any parameters besides the test? Is the new module faulty?
Oh, one other thing! If I turn the power switch on, the machine starts - - even with the door open It begins draining, then begins filling with water. I then close the door, not wanting to see how the washer works with the door open! I replaced the door switch (from AppliancePartsPros.com) and it is verified by continuity test to work. In spite of this properly operating switch, the machine still starts with the door open.
Thanks, Li
Related Models
Bosch SHV4303 UC/06
Bosch SHV4303 UC/06 (FD 7712-8002)
Bosch SHV4303 UC/11
Bosch SHV4303 UC/11 (FD 8002-8003)
Bosch SHV4303 UC/12
Bosch SHV4303 UC/12 (FD 8003-)
Bosch SHV46C03 UC/14 (FD 8211-)
Bosch SHV4803 UC/06
Bosch SHV4803 UC/06 (FD 7712-7812, 7905-7907)
Bosch SHV4803 UC/07
Bosch SHV4803 UC/07 (FD 7812-7905, 7907-8010)
Bosch SHV4803 UC/12
Bosch SHV4803 UC/12 (FD 8010-)
Bosch SHV66A03 UC/14 (FD 8301-)
Bosch SHV6803 UC/12 (FD 8105 -)
Bosch SHV99A03 UC/14 (FD 8212-)
Hoover SHWA2501A Washer - Top Loading
Hoover SHWA2501W Washer - Top Loading
Hoover SHWA2506A Washer - Top Loading
Hoover SHWA2506AT Washer - Top Loading
Hoover SHWA2506W Washer - Top Loading
Hoover SHWA2506WT Washer - Top Loading
Hoover SHWA2507A Washer - Top Loading
Hoover SHWA2507V Washer - Top Loading
Hoover SHWA2507W Washer - Top Loading
Bosch SHX33A02 UC/14 (FD 8211-)
Bosch SHX33A05 UC/14 (FD 8211-)
Bosch SHX33A06 UC/14 (FD 8211-)
Bosch SHX43E02 UC/14 (FD 8211-)
Bosch SHX43E05 UC/14 (FD 8211-)
Bosch SHX43E06 UC/14 (FD 8211-)
Bosch SHX46A02 UC/14 (FD 8211-)
Bosch SHX46A05 UC/14 (FD 8211-)
Bosch SHX46A06 UC/14 (FD 8211-)
Bosch SHX46A07 UC/14 (FD 8211-)
Bosch SHX46B02 UC/14 (FD 8211-)
Bosch SHX46B05 UC/14 (FD 8211-)
Bosch SHX46B06 UC/14 (FD 8211-)
Bosch SHX46B07 UC/14 (FD 8211-)
Bosch SHX56B02 UC/14 (FD 8211-)
Bosch SHX56B05 UC/14 (FD 8211-)
Bosch SHX56B06 UC/14 (FD 8211-)
Bosch SHX99B05 UC/14 (FD 8212-)
Bosch SHX99B06 UC/14 (FD 8212-)
Bosch SHY56A02 UC/14 (FD8301-)
Bosch SHY56A05 UC/14 (FD8301-)
Bosch SHY56A06 UC/14 (FD8301-)
Bosch SHY66C02 UC/14 (FD8301-)
Bosch SHY66C05 UC/14 (FD8301-)
Bosch SHY66C06 UC/14 (FD8301-)
Bosch SHY99A02 UC/14 (FD 8212-)
Bosch SHY99A05 UC/14 (FD 8212-)
Bosch SHY99A06 UC/14 (FD 8212-)
Amana SI19E Ref - SXS/I&W
General Electric SIG7010ET1WG Electric dryer
International SILVER22 Ref - SXS/I&W
International SILVER24 Ref - SXS/I&W
Maytag SK525-2W  Ref - Sxs
Maytag SK535-2  Ref - SXS/I&W
Gaggenau SK590-2  Ref - Bottom Mounts
Hardwick SKG4622MGA639R Range - F/s Cont Clean Gas
Hardwick SKG4622MGW639R Range - F/s Cont Clean Gas
Hardwick SKG9611A540R Range - F/s Cont Clean Gas
Hardwick SKG9611W540R Range - F/s Cont Clean Gas
Amana SKI22F Ref - SXS/I&W
Amana SKI22F-A Ref - SXS/I&W
Amana SKI22F-C Ref - SXS/I&W
Amana SKI22F-G Ref - SXS/I&W
Amana SKI22FL Ref - SXS/I&W
Hardwick SKJ7141819DE Walloven - Cont Clean Gas
Maytag SL10AA Stacked Laundry - Ele
Maytag SL10AA-A01 Stacked Laundry - Ele
Maytag SL10AN Stacked Laundry - Ele
Maytag SL10AN-A00 Stacked Laundry - Ele
Maytag SL10AN-A01 Stacked Laundry - Ele
Maytag SL10AN-A02 Stacked Laundry - Ele
Maytag SL10AN-A03 Stacked Laundry - Ele
Maytag SL11AA Stacked Laundry - Ele
Maytag SL11AN Stacked Laundry - Ele
General Electric SL208 Room air conditioner
General Electric SL210 Room air conditioner
General Electric SL212 Room air conditioner
General Electric SL214 Room air conditioner
General Electric SL217 Room air conditioner
General Electric SL220 Room air conditioner
General Electric SL223 Room air conditioner
Amana SL22F Ref - SXS/I&W
Amana SL22F-A Ref - SXS/I&W
Amana SL22F-C Ref - SXS/I&W
Amana SL22F-G Ref - SXS/I&W
Amana SL22F-L Ref - SXS/I&W
Amana SL22G Ref - SXS/I&W
Amana SL22GL Ref - SXS/I&W
Amana SL22JB Ref - SXS/I&W
Amana SL22MBG Ref - SXS/I&W
Amana SL22MBL Ref - SXS/I&W
Amana SL22MBW Ref - SXS/I&W
Amana SL25G Ref - SXS/I&W
Amana SL25GL Ref - SXS/I&W
Amana SL25H Ref - SXS/I&W
Amana SL25J Ref - SXS/I&W
Amana SL25M2L Ref - SXS/I&W
Amana SL25M2W Ref - SXS/I&W
Amana SL25MG Ref - SXS/I&W
Amana SL25ML Ref - SXS/I&W
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Advantium Display Blanking Out pgmr Microwave Repair 4 10-21-2007 03:09 AM
Whirlpool washer will not advance cycles GARY H Washer Repair 0 08-14-2007 07:18 PM
Doesn't Run, No Display. Singer Dishwasher Repair 4 08-13-2007 01:27 PM
Ice dispenser is inop jodava Refrigerator & Freezer Repair 1 07-30-2007 07:01 PM
Only 8's showing on the erc display BruceL Oven Repair (including Ranges and Cooktops) 1 07-22-2007 11:20 PM
