Discuss
no pressure to upper spray arm
 in
Dishwasher Repair
HELP !! If I don't get this fixed soon..... I'll have to do the dishes....... It's almost playoffs....
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » no pressure to upper spray arm
  #1 (permalink)
Old 03-18-2008, 06:09 PM
yrnut yrnut is offline
Junior Member
yrnut is on a distinguished road
Exclamation no pressure to upper spray arm
Model Number: 17519201   Brand: Kenmore   Age: 1 - 5 years
HELP !! If I don't get this fixed soon..... I'll have to do the dishes....... It's almost playoffs....I have a Kenmore dishwasher Model #17519201. There is no pressure to the upper washing arm under the upper dish rack.
It has a pipe that runs from the pump at the bottom of the unit, up the back of the inside of the dishwasher.When you push the upper rack in to close the door it seems the under rack spray arm seems to couple to that rear pipe. Is there a bushing, gasket etc. that is supposed to make a water tight connection when the rack is pushed in? It would seem to be missing. Is there a part number or a way to find an exploded view of that section so I can order it?
Thanks,
AL
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-18-2008, 07:14 PM
Aries Aries is offline
Junior Member
Aries is on a distinguished road
Default
no gasket or seal on mine... top rack just slides into it. How do you know water isnt getting up there?
If it isnt, maybe something is blocked or the pump is broke?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No water in upper spray arm caveman Dishwasher Repair 0 02-12-2008 09:03 AM
Upper spray arm not effective aak11 Dishwasher Repair 2 01-10-2008 11:08 AM
Upper spray arm does not rotate btd Dishwasher Repair 2 01-04-2008 09:31 PM
Low pressure at spraybars Snearxx Dishwasher Repair 0 12-09-2007 03:26 AM
gas pressure adjusment tuta68 Oven Repair (including Ranges and Cooktops) 1 08-09-2007 06:50 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
