Discuss
Dishwasher clean light keeps flashing
 in
Dishwasher Repair
The clean light flashes in intervals of 7 flashes. When I push the cancel button the number 2 will appear
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher clean light keeps flashing
  #1 (permalink)
Old 12-14-2009, 04:40 PM
Junior Member
gfroman is on a distinguished road
Unhappy Dishwasher clean light keeps flashing
Brand: Whirlpool   Age: 1 - 5 years
The clean light flashes in intervals of 7 flashes. When I push the cancel button the number 2 will appear in the display window and the dishwasher will start and countdown and then stop. Light will still flash and when I push the button to start a cycle it just shows 2 dotted lines in the display and will not start. It is a 2 year old Whirlpool Gold Quiet Partner III model number GU2400.
Ads By Google
  #2 (permalink)
Old 12-15-2009, 02:31 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
A model number may help others help you
__________________
  #3 (permalink)
Old 12-15-2009, 05:38 AM
Junior Member
Default
Thank you! I have added it to my post.
  #4 (permalink)
Old 12-15-2009, 06:22 AM
Senior Expert
APP Volunteer
Default
Your model number is short a number of digits, should have something similar to XTPB4 at the end.
There are a number of different series of units under the GU2400 model.
__________________
  #5 (permalink)
Old 01-06-2010, 07:18 AM
Junior Member
Default
Sorry, for the long delay. I finally have the complete model number.
GU2400XTPT6 Whirlpool Gold Quiet Partner III - 3 years old
Your help is much appreciated.....tired of washing dishes
  #6 (permalink)
Old 01-06-2010, 12:23 PM
Senior Expert
APP Volunteer
Default
Here are the parts
Replacement parts for WHIRLPOOL GU2400XTPT6 Dishwasher | AppliancePartsPros.com
And here is the tech sheet which has info on your problem
http://www.servicematters.com/docs/w...%208535451.pdf
__________________
  #7 (permalink)
Old 01-23-2010, 10:33 AM
Junior Member
WHardwick is on a distinguished road
Default Clean Light keeps flashing GU2400XTPS1
I have the same problem with my Whirlpool dishwasher GU2400XTPS1 the light keeps flashing and when I press cancel the pump turns on and I get the number two. I was following the thread here, but there was no solution? any help would be appreciated.
  #8 (permalink)
Old 01-23-2010, 11:10 AM
Junior Member
Smile whirlpool gold dishwasher
Here is what we did to our dishwasher and it is working fine now.....hope this helps you as well.
With the door closed push the NORMAL button then immediately push the HEATED DRY button do this 2 - 3 times until the whole control panel lights up - then push start.
After pushing start our dishwasher showed 17 in the display window and finished the cycle. It has worked fine since then.
I read somewhere that this is sometimes caused due to the temperature of the water not being hot enough. I always try to remember to run the hot water in the sink for a few minutes before I start the dishwasher.
  #9 (permalink)
Old 01-27-2010, 02:08 AM
Senior Expert
APP Volunteer
Default
WHardwick
Here is the tech sheet for your unit, it goes over the flashing light problem and how to reset.
Can be the water is too cold, heater blown, hi-limit thermostat blown, thermistor problem or the timer.
If the heater comes on during dry then the heater and the hi-limit are OK
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
"CLEAN" cycle light always flashing Tadek Dishwasher Repair 11 01-04-2012 12:29 PM
Clean light flashing, will not run bclout Dishwasher Repair 0 02-21-2010 03:11 PM
Flashing clean light Whirlpool D/W HARRYms Dishwasher Repair 1 12-19-2009 05:06 AM
dishwasher clean light is flashing Marcello Dishwasher Repair 1 10-03-2008 10:27 AM
Clean light flashing after cleaning lildiesel59 Oven Repair (including Ranges and Cooktops) 2 06-20-2008 08:02 AM
