J Ebne
#1 Posted : Sunday, December 13, 2009 10:30:36 AM(UTC)
J Ebne
Heating element of GE GHDA485N10CS does not come on. only 14 months old. Everything else works ok, goes through full cycles. How do you determine repair and replace non-working parts???
#2 Posted : Sunday, December 13, 2009 1:03:27 PM(UTC)
Here are your parts> Yours is probably just newer but if ordering parts be sure to use your model number as there may have been some changes
Replacement parts for GHDA485N10CS models | AppliancePartsPros.com
Easiest way is to check the heating element with a meter.
Remove power from the unit, unplug one side of the element and measure it.
Usually between 10 to 25 ohms.
If OK check that the wires from the time/control to the heater have continuity. Could be one of them has kinked and is open.
If all OK the control board probably needs replacing re: the contacts on the heating relay have burned up or the relay is not closing.
If the element is shot you may also want to replace it's sealing grommets, in case they get screwed up when you remove the element.
NOTE: Getting tech info on GE's is difficult to say the least. They like to keep is a secret. Hopefully when you remove the kick plate you will find the wiring diagram which should be very useful. Some units use a thermistor or a thermostat to regulate the heater, I could not find either in the parts breakdown but may have missed them. If the unit does use these then they are another possible cause.
Also check for a hi-limit thermostat wired into the lines going to the heater., if there is one it should be 0 ohms.
Perhaps someone else will jump in who has better info on this unit.
