Discuss
Leaking valve
 in
Dishwasher Repair
We have had an intermittent problem with our Bosch SMU 2046 UC/14. Clean water pooling at the bottom of
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Leaking valve
  #1 (permalink)
Old 03-16-2008, 03:35 PM
Watt Watt is offline
Junior Member
Watt is on a distinguished road
Default Leaking valve
Model Number: SMU2046 UC/14   Brand: Bosch   Age: 5 - 10 years
We have had an intermittent problem with our Bosch SMU 2046 UC/14. Clean water pooling at the bottom of the dishwasher between washes (and on the floor upon opening the washer door!) We had assumed that the problem was cleaning the filter, making sure the garbage disposal and sink were cleaned, and saw online that perhaps the water pump or the water valve could be involved.
Upon study, there is now a slow steady stream of water coming from the vent on the left wall of the inner casing. This stops when I turn the water off. I can't find information about what this vent does, and why water would be coming out of it.
According to the diagram from the Bosch manual online, these parts are the cover 065290, the seal 065303, and the insert 056824. According to the appliancepartspros parts search, these same parts are the vent cover AP2802244, Gasket AP2802242, and the vent ensert AP2802208. There is reference that the gasket is discontinued?
We are trying to determine if a repair is economical or possible, or whether we should lean towards a replacement as there is a spot in the top rack that is corroded, and spots on the front panels that are a tad rusty, these parts retail $162, $40 and $20. It also seems that plastics don't dry as well lately so perhaps the heating element might less efficient.
Any advice? Thanks!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-16-2008, 05:45 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
if water is pooling inside of dishwasher even after totaly draining water valve at front left side bottom behind kick plate needs replacing
__________________
  #3 (permalink)
Old 03-16-2008, 06:25 PM
Junior Member
Default Thanks and a question
Thanks for your reply. It is helpful to know where the water valve is.
So would the water valve then leak through the vent which is about 1/2 way up on the left side? Is that what that vent is for, water coming in?
  #4 (permalink)
Old 03-21-2008, 05:52 PM
Carson1214 Carson1214 is offline
Junior Member
Carson1214 is on a distinguished road
Default
The vent is used for bot venting the unit and as the filling point of the unit as your valve leaks enought to reach the vent you then see the water enter the unit.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ge Water Valve txjames101@yahoo.com Refrigerator & Freezer Repair 3 09-13-2008 04:37 PM
safety valve adepinto Oven Repair (including Ranges and Cooktops) 3 02-02-2008 08:08 PM
venturi and gas valve vornato Oven Repair (including Ranges and Cooktops) 0 01-01-2008 05:38 AM
Ice maker still leaking - Just replaced fill valve Adam80 Refrigerator & Freezer Repair 1 09-12-2007 08:09 PM
Ge inlet valve Mark Dishwasher Repair 1 07-20-2007 07:22 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
