| » Will not drain at the end of the cycle |
Model Number: DU89OSWKQO Brand: Whirlpool Age: 5 - 10 years
If the timer is turned to the rinse cycle manualy after the dry cycle is done it will drain and dry.
Pump and spray arm replacement parts for WHIRLPOOL DU890SWKQ0 | AppliancePartsPros.com Here is the tech sheet and a manual http://www.servicematters.com/docs/w...%208275136.pdf https://secured.whirlpool.com/Servic...LE/4322430.pdf Check/clean the drain system Check/clean the pump If both the above are OK then it could be the timer.
__________________
| Display Modes | |
| washing machine stops after agitating cycle, doesn't drain or proceed to next cycle | jjd2009 | Washer Repair | 2 | 11-13-2009 06:31 AM |
| bosch shu9925 - drain pump works, won't drain after cycle | mjbarr | Dishwasher Repair | 0 | 10-16-2009 01:11 PM |
| Will not drain during cycle | automace | Dishwasher Repair | 1 | 04-25-2009 10:07 PM |
| Won't drain last cycle | jbo | Dishwasher Repair | 4 | 07-26-2008 06:39 AM |
| Stuck in drain cycle | glbray1 | Dishwasher Repair | 0 | 11-04-2007 08:38 AM |
