Discuss
Dishwasher will not drain
 in
Dishwasher Repair
DW works fine but will not drain. The only hose I can see under the sink looks like the water
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher will not drain
  #1 (permalink)
Old 12-10-2009, 09:21 PM
Junior Member
Stardell is on a distinguished road
Default Dishwasher will not drain
Brand: Jenn-Air   Age: 1 - 5 years
DW works fine but will not drain. The only hose I can see under the sink looks like the water line. Nothing connects to the disposal,other than the drain from the sink. I cannot locate a diagram for the Jenn-Air JDB6510 to do any closer examination. Side note: the outside temperature has been between 12 and 30 degrees. Help.
Ads By Google
  #2 (permalink)
Old 12-12-2009, 04:14 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here are parts for your unit re:AWP
Pump & motor replacement parts for JENN-AIR JDB6510AWP Dishwasher - Undercounter | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/maytag...s/16022580.pdf
First you have to determine is if it is trying to drain.
If yes then it is probably a drain line or a pump problem.
If no then it is either a timer or a motor problem.
Am not sure why you mentioned the outside temperature?
__________________
  #3 (permalink)
Old 12-21-2009, 12:05 PM
Junior Member
olypm is on a distinguished road
Default
Do you have a Johnson T value air vent which vents to outside? It might have froze solid. I suggest this because, (a) you don't see a drain line, Johnson T values drain into a copper pipe that goes into the wall behind the DW. You should see a vent on your outside wall kind of behind and above the dishwasher. (b) If the P trap in the Johnson T value froze, it blocks the DW from draining, but everything else works fine.
There are also vents that vent into the wall cavity. I don't know if these are code or not, but I've seen them (Home Depot).
I figured this was the problem on my DW by taking it out and running a cycle with it draining into the sink just to make sure the DW was working okay. Next I blew air into the drain pipe and it was plugged. I waited a couple days and it thawed and I put everything back. Oh, I used a shopvac to drain the standing water in the DW first.
Johnson T's are bad, bad, bad. They were big in the 1990's with granite kitchens. If that is what you have, consider retrofitting around it (into the disposer, etc.).
Hope this helps,
Jeff
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher will not drain GoBlue Oven Repair (including Ranges and Cooktops) 3 08-19-2009 11:21 PM
Dishwasher won't drain Ikekey Dishwasher Repair 0 06-12-2009 08:20 PM
Dishwasher does not drain iwen Dishwasher Repair 0 03-14-2009 12:01 PM
dishwasher won't drain goinglogo Dishwasher Repair 0 01-11-2009 06:12 AM
dishwasher won't drain sandmancan Dishwasher Repair 0 12-25-2008 09:10 AM
