Appliance Repair Forum
-   Dishwasher Repair (http://forum.appliancepartspros.com/dishwasher-repair/)
-   -   Jenn-Air start light not turning on, touch panel or control board? (http://forum.appliancepartspros.com/dishwasher-repair/62869-jenn-air-start-light-not-turning-touch-panel-control-board.html)
christianausa 10-08-2014 12:45 PM
Denmans recommendation for JenAir Dishwasher
My control panel had stopped working and I tried turning off the breaker for a couple of days, no luck, then I took the dishwasher apart and did what Denman suggested. It seemed very simple was not sure if it would work, so I waited over 6 weeks until I did finally did it.
It worked, I just ran a full cycle. I will run it again with dishes later today.
Thank you Denman for your help. :) [/size][/font]
Christiana
Seattle WA
losangelesdweller 05-15-2016 08:50 PM
I have the same problem, but turning off the breaker or replacing the touch panel did not do anything. This all started after I got some water into the door (poor gasket installation) and opened the door. I suppose I could have damaged something either while taking the door apart, or because of water.
Control panel seems sealed enough, so does not seem likely that it's the problem. I checked the contacts. Don't know what else I can check :(
I wonder if something could have gone wrong with the door switch? (My start button used to light up before you close the door)
