Discuss
Is it my fill valve?
 in
Dishwasher Repair
My dishwasher isn't filling to the correct water level. According to the paperwork I have when I purchased the dishwasher
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Is it my fill valve?
  #1 (permalink)
Old 12-05-2009, 02:39 PM
Junior Member
factorypilot is on a distinguished road
Default Is it my fill valve?
Model Number: GU980SCGB3   Brand: Whirlpool   Age: 5 - 10 years
According to the paperwork I have when I purchased the dishwasher I should have two qts of water from the supply line in 27 seconds which I exceed by a wide margin. I should also have approx. 2.2 gallons after the fill which I am no where near.
What I have done so far is disconnect the supply line and run it into a bucket to confrim the supply as indicated above. I timed the fill cycle at two minutes which again from the paperwork should be spot on. I left the door cracked to see if water was possibly draining on its own which it is not. I drained the water and measured out two gallons and poured it in the tub to get an idea of the correct water level, which I am way short on.
So I am leaning torward a fill valve. Can anyone confirm if I am on target here or is there another componet that can cause the issue I have? We do have hard water and I do get rust stains in the tub even though we have a water softner. I think we might have a tank on the water heater going bad. Just wanted to add this info if it may lead to something else with the washer.
Thanks.
Ads By Google
Related Models
Whirlpool GU980SCGB3 DISHWASHER
Whirlpool GU980SCGQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGQ2 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGQ3 DISHWASHER
Whirlpool GU980SCGS1 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGS2 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGS3 DISHWASHER
Whirlpool GU980SCGT2 DISHWASHER
Whirlpool GU980SCGT3 DISHWASHER
Whirlpool GU980SCGZ0 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGZ1 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGZ2 UNDERCOUNTER DISHWASHER
Maytag GV1110PRW RANGE- F/S STD GAS
Admiral GV1226NXEW FREEZER- VERTICAL
Admiral GV1726NXEW FREEZER- VERTICAL
Hoover GV3177WUA RANGE- F/S STD GAS
Hoover GV3177WUW RANGE- F/S STD GAS
Hoover GV3177WUW5 RANGE- F/S STD GAS
Maytag GV3277XUA RANGE- F/S STD GAS
Maytag GV3277XUW RANGE- F/S STD GAS
Hoover GV3531WUA RANGE- F/S STD ELE
Hoover GV3531WUW RANGE- F/S STD ELE
General Electric GVSR1060H7WW WASHER
General Electric GVSR1060H9WW WASHER
General Electric GVSR1080H8WW WASHER
Whirlpool GVW9959KL0 WASHER
Whirlpool GVW9959KL1 WASHER - DIRECT DRIVE
Whirlpool GVW9959KL2 WASHER - DIRECT DRIVE
Whirlpool GVW9959KL3 AUTOMATIC WASHER
Whirlpool GVW9959KQ0 WASHER
Whirlpool GVW9959KQ1 WASHER - DIRECT DRIVE
Whirlpool GVW9959KQ2 WASHER - DIRECT DRIVE
Whirlpool GVW9959KQ3 AUTOMATIC WASHER
Whirlpool GVW9959KT0 WASHER
Whirlpool GVW9959KT1 WASHER - DIRECT DRIVE
Whirlpool GVW9959KT2 WASHER - DIRECT DRIVE
Whirlpool GVW9959KT3 AUTOMATIC WASHER
Maytag GW18F1A WASHER-TOP LOADING
Maytag GW18F1H WASHER-TOP LOADING
Maytag GW18F1W WASHER-TOP LOADING
Maytag GW18F2A WASHER-TOP LOADING
Maytag GW18F2H WASHER-TOP LOADING
Maytag GW18F2W WASHER-TOP LOADING
Maytag GW18G1A WASHER-TOP LOADING
Maytag GW18G1HW WASHER-TOP LOADING
Maytag GW18G1WW WASHER-TOP LOADING
Maytag GW20F6A WASHER-TOP LOADING
Maytag GW20F6H WASHER-TOP LOADING
Maytag GW20F6W WASHER-TOP LOADING
Frigidaire GW30SPEA2 Wwh(v1) / Electric Range
Frigidaire GW30SPED1 Wwh(v2) / Electric Range
Frigidaire GW30SPEW1 Wwh(v1) / Electric Range
Frigidaire GW30SPEW2 Wwh(v2) / Electric Range
Whirlpool GW395LEGB0 GAS RANGE
Whirlpool GW395LEGB1 GAS RANGE
Whirlpool GW395LEGB2 GAS RANGE
Whirlpool GW395LEGB3 GAS RANGE
Whirlpool GW395LEGB4 GAS RANGE
Whirlpool GW395LEGB5 GAS RANGE
Whirlpool GW395LEGB6 GAS RANGE
Whirlpool GW395LEGQ0 GAS RANGE
Whirlpool GW395LEGQ1 GAS RANGE
Whirlpool GW395LEGQ2 GAS RANGE
Whirlpool GW395LEGQ3 GAS RANGE
Whirlpool GW395LEGQ4 GAS RANGE
Whirlpool GW395LEGQ5 GAS RANGE
Whirlpool GW395LEGQ6 GAS RANGE
Whirlpool GW395LEGT2 GAS RANGE
Whirlpool GW395LEGT3 GAS RANGE
Whirlpool GW395LEGT4 GAS RANGE
Whirlpool GW395LEGT5 GAS RANGE
Whirlpool GW395LEGT6 GAS RANGE
Whirlpool GW395LEGZ0 GAS RANGE
Whirlpool GW395LEGZ1 GAS RANGE
Whirlpool GW395LEGZ2 GAS RANGE
Whirlpool GW395LEGZ3 GAS RANGE
Whirlpool GW395LEPB00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW397LXUB0 30" Gas Slide-In
Whirlpool GW397LXUB05 30" GAS SLIDE-IN
Whirlpool GW397LXUB06 30" GAS SLIDE-IN RANGE
Whirlpool GW397LXUB1 30" GAS SLIDE-IN
Whirlpool GW397LXUB5 30" GAS SLIDE-IN
Whirlpool GW397LXUQ0 30" Gas Slide-In
Whirlpool GW397LXUQ06 30" GAS SLIDE-IN
Whirlpool GW397LXUQ1 30" GAS SLIDE-IN
Whirlpool GW397LXUQ6 30" GAS SLIDE-IN
Whirlpool GW397LXUS0 30" Gas Slide-In
Whirlpool GW397LXUS05 30" GAS SLIDE-IN
Whirlpool GW397LXUS06 30" GAS SLIDE-IN RANGE
Whirlpool GW397LXUS1 30" GAS SLIDE-IN
Whirlpool GW397LXUS5 30" GAS SLIDE-IN
Whirlpool GW397LXUT0 30" Gas Slide-In
Whirlpool GW397LXUT05 30" GAS SLIDE-IN
Whirlpool GW397LXUT06 30" GAS SLIDE-IN
Whirlpool GW397LXUT1 30" GAS SLIDE-IN
Whirlpool GW397LXUT5 30" GAS SLIDE-IN
  #2 (permalink)
Old 12-05-2009, 03:01 PM
Member
gmbdinc is on a distinguished road
Default
Check your float switch AP2909457 Diagram #3. Even though the "time" may be right, the float switch cuts the water off when it is to the right level. Not everyboy has the same watervolume/pressure. The Time is just to make sure it has more than enough" time" to fill. This is a check for continuity... disconnect the voltage. Manually operate the float to make sure it goes off(UP) and on(DOWN). Being you have hard water , the float may also be sticking.
  #3 (permalink)
Old 12-05-2009, 03:16 PM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Have you checked the screen filter on the inlet side of the fill valve.
If dirty clean it, do not remove it as it is there to keep crud out of the valve which could hold it open and cause a flood.
Also check that it is not coated with calcium deposits.
You may want to drain some water out of your hot water tank, crud etc. can collect in the bottom of tha tank and will eventually build up to the point that it gets into the water lines.
__________________
  #4 (permalink)
Old 12-05-2009, 05:14 PM
Junior Member
Default
I'm not familiar with the sreen on the fill valve, where would I see it if I had the fill valve in my hand? I'm guessing if I said disconnect the supply line and look in or do I need to take some of the fill valve apart?
Will check the float switch tomorrow.
  #5 (permalink)
Old 12-06-2009, 12:43 AM
Senior Expert
APP Volunteer
Default
Yes just remove the valve and look into the input fitting.
__________________
  #6 (permalink)
Old 12-18-2009, 06:04 PM
Junior Member
Default
Just a follow up on what I found. I took the fill valve bracket out of the machine with the fill valve attached less electrical and water connections.. I then removed 4 screws that held the fill valve to the bracket and the valve separated into two pieces. This is where I found the screen on this unit. It was full of deposits. After cleaning and reassembly dishwasher now fills to proper level.
Thanks denman.
  #7 (permalink)
Old 12-18-2009, 07:33 PM
Senior Expert
APP Volunteer
Default
Glad to hear you are up and running
Thanks for getting back to us
Have a Happy Holiday Season
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fill valve won't stop. Outtasite Dishwasher Repair 3 01-27-2010 01:59 AM
Where is KA DW Fill Valve? bhh626 Dishwasher Repair 3 05-20-2009 03:17 PM
wont fill is it the fill valve acman727 Dishwasher Repair 1 03-14-2009 04:40 PM
No power to fill valve rumney11 Dishwasher Repair 0 07-23-2008 01:43 PM
How can I test a fill valve? geoghegan Dishwasher Repair 1 01-31-2008 07:41 PM
