Discuss
Grinding Noise - Kitchen Aid Dish Washer
 in
Dishwasher Repair
There is a loud grinding noise as soon as the motor starts. Also there is water dripping around the motor
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Grinding Noise - Kitchen Aid Dish Washer
  #1 (permalink)
Old 03-11-2008, 06:37 PM
RSC RSC is offline
Junior Member
RSC is on a distinguished road
Default Grinding Noise - Kitchen Aid Dish Washer
Model Number: KUDM24SEBL1   Brand: Kitchen Aid   Age: 5 - 10 years
There is a loud grinding noise as soon as the motor starts. Also there is water dripping around the motor underneith. Not heavy but a constant drip. Any suggestions?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-12-2008, 05:30 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the pump seals are leaking.
If the motor bearing is not rusted yet, you can fix it by installing a new impeller kit.
If the motor bearing is already rusted, you have to replace the whole pump & motor assembly.
In both cases the pump & motor assembly has to be removed from the dishwasher but you do not need to remove the dishwasher from the cabinet.
If you are going to fix the old pump - the gasket around the pump housing has to be replaced too. You do not have to order it if you replace the whole pump & motor assembly - it's included.
- The part number for the impeller kit is AP3115180
- The part number for the housing gasket is AP2908993
- The part number for the pump & motor assembly is AP3776341
Here are the break down diagrams for the Kitchen Aid dishwasher Model KUDM24SEBL1
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 03-12-2008, 07:40 PM
RSC RSC is offline
Junior Member
Default grinding noise and leak
Gene...Thank you for your reply. I was able to get down to the impeller and found it severely broken. I may have located the impeller kit locally and will see if that does the fix. If not I will order the complete motor unit from Appliance Parts Pro. Again, thank you for your reply.
RSC
  #4 (permalink)
Old 03-13-2008, 04:50 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
I would run the dishwasher to see if the motor bearings are bad. If they are, new motor time, if not, I have used a sharp wood chisel on the old impeller to bust it out. Post results.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ge washer makes lound grinding noise is spin cycle. tater Washer Repair 7 03-24-2008 06:57 PM
Washer makes grinding noise. wont spin montanaJohn Washer Repair 3 01-21-2008 07:52 PM
Kenmore Washer Series 80. Won't spin, agitate and makes a grinding noise Scottmcc Washer Repair 6 01-05-2008 08:24 AM
Grinding noise from washer jreynolds Washer Repair 2 12-27-2007 03:05 AM
Washer won't complete cycle-grinding noise rebekah Washer Repair 2 12-13-2007 08:20 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
