Dishwasher won't turn on, no lights on front, I have checked door switch and power distribution behind kick panel.
Open the control panel and check for 120VAC between the black and white wires at the plug D on the control board (incoming power). If the reading is correct, replace the control board. - The control board Part number: AP3156133
