katiedbell
#1 Posted : Sunday, November 29, 2009 4:50:08 PM(UTC)
katiedbell
We just noticed that our GE dishwasher is leaking. It seems to becoming from under the appliance...and it is dripping from some tub/box that is yellowish in colour right in the middle of the machine....does anyone know what could be causing it and how I go about fixing it?? :confused: thanks so much!!! :)
applianceman
#2 Posted : Sunday, November 29, 2009 7:53:52 PM(UTC)
applianceman
If it is leaking at the motor shaft the pump seal is bad.
Sometimes it will leak from the rubber coupling above the motor and the water will run between the motor. It will look like it is leaking from the shaft so check that good.
This page will help with both GE Dishwasher Pump Leaking Repair Guide
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
ge dishwasher leaking at bottom (Dishwasher Repair)
by Jerry7235 10/31/2013 1:48:10 PM(UTC)
GE Dishwasher leaking at shaft near solenoid valve (Dishwasher Repair)
by e-man 8/14/2011 6:55:10 PM(UTC)
GE Dishwasher Leaking Out Through Water InFeed during aggitation (Dishwasher Repair)
by andrewmcc 3/26/2011 3:20:29 PM(UTC)
GE dishwasher leaking at bottom right front door (Dishwasher Repair)
by ZincWhiskers 3/23/2010 12:03:20 PM(UTC)
GE Dishwasher leaking (Dishwasher Repair)
by must9450 9/11/2009 1:27:16 PM(UTC)
by _Joe_ 8/6/2009 8:52:48 AM(UTC)
GE Dishwasher Leaking (Dishwasher Repair)
by leland48 4/15/2009 7:32:25 AM(UTC)
GE Dishwasher Leaking from fitting below washer arm (Dishwasher Repair)
by DeG6 11/25/2008 11:59:59 PM(UTC)
GE dishwasher leaking (Dishwasher Repair)
by Chuck Hamby 11/9/2008 10:33:16 AM(UTC)
