Discuss
Maytag dishwasher -touch pad control panel
 in
Dishwasher Repair
Please Help Me with my Control panel problems! All the cycle selections of the control panel touch pad stopped working.
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Maytag dishwasher -touch pad control panel
  #1 (permalink)
Old 11-28-2009, 04:28 AM
Member
tommyboy84 is on a distinguished road
Default Maytag dishwasher -touch pad control panel
Brand: Maytag   Age: Less than 1 year
My dishwasher will not run with the 'norm', 'light', 'rinse' or 'heavy wash' touch pad selections. None of these lights come on anymore.
It only will function on the 'Auto Wash' touch pad selection.
It will probably stop working all together, very soon!
Model # MDB8851AWS
Any suggestions will help.
Thanks, Tommyboy84
  #2 (permalink)
Old 11-28-2009, 05:06 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for MAYTAG MDB8851AWS10 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/w...0W10128608.pdf
Looks like they all use Pin 9 as the common so this may be the problem.
Auto uses a different pin.
I would do the following connector cleaning.
Pay special attention to the ribbon cable Pin 9 track.
If this does nothing then I would check the keypad with a meter. If OK then the control board is the likely culprit but is is still a bit of a crap shoot.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
__________________
  #3 (permalink)
Old 11-28-2009, 05:21 AM
Member
Default
Thank YOU Denman!
I'll give your suggestions a try and let you know how I made out.
tommyboy84
  #4 (permalink)
Old 11-28-2009, 07:26 AM
Member
Default After cleaning connector and ribbon wire
After cleaning connector and ribbon wire my dishwasher still does as I first described, no led display and no action from any of the 'cycle selection' touch pads except the 'auto clean' pad. No small cracks, ribbon like new!
Here is the interesting observation:
I ran the Field service test after I had cleaned the connections and
all the LED's came on as described in the instructions and the 'heavy wash' led
is blinking during the test as described. LED's are at least operable.
Any thoughts?
Do you know why All the LED's would work during the field test, but not normally?
The number 9 pin must be good a connection - correct?
Thanks again, Tommyboy84
  #5 (permalink)
Old 11-28-2009, 08:04 AM
Senior Expert
APP Volunteer
Default
Any thoughts?
They work because they are forced on by the program.
Does not really tell you as the diags do not include a keypad test.
If you run the manual test then you can tell if at least some of the keys are OK, since you have to step to the some tests using the Normal key.
__________________
  #6 (permalink)
Old 11-28-2009, 09:08 AM
Member
Default Manual Test
I ran the Manual test, It worked as described up to the point of the 'Normal wash' Key. It is dead- does not do anything- does not light up.
I had to cancel the manual test at that point.
All the cycle keys - don't do anything - other than 'Auto wash' Key...
I'm back to square one.
How do I test the Key pad? I test for continuity between the various pins
i.e. Pin 9 - Pin 6 for 'Normal Wash, Pin 9 - Pin 5 for 'Heavy Wash', Etc.?
I should have a completed circuit when the correct key is pressed .
I would be disconnecting the ribbon from the control board again and taking my measurements at that point.- correct?
Thank You again
  #7 (permalink)
Old 11-28-2009, 11:09 AM
Senior Expert
APP Volunteer
Default
No you are further ahead as now you know that it is probably the keyboard you just have to double check it.
Yes, just be sure your keypad matches the pin-outs
Not pushed should be infinite ohms.
Pushed should be 10,000 ohms
They do not mention it but it may be polarity dependant so try swapping meter leads on the tracks if you just get an open/infinite.
Try the key that you know works first then you will know what to expect.
Yes
__________________
  #8 (permalink)
Old 05-17-2013, 12:27 PM
Junior Member
cm1js is on a distinguished road
Default control panel and wiring harness
Thanks Tommieboy. I went ahead and ordered the panel with the and got it repaired. I appreciate the offer. Works great now.
  #9 (permalink)
Old 05-17-2013, 02:06 PM
Junior Member
radiokrislee is on a distinguished road
Default Class Action Against Whirlpool (Maytag) Regarding Control Panels
I have filed a class action lawsuit against Whirlpool for their faulty control panels in their Whirlpool and Maytag dishwashers. Please contact my attorney Eppsteiner & Fiorica Attorneys, LLP at 866.548.8857 and let them know if you own or owned a dishwasher with control panel failures.
Quote:
  #10 (permalink)
Old 05-17-2013, 03:18 PM
Member
Default
Welcome, glad you got it working.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Control Panel Problems for Maytag Dishwasher tommyboy84 Dishwasher Repair 7 05-17-2013 06:56 AM
Replacing a Maytag Dishwasher Control Panel retirednow Dishwasher Repair 4 03-20-2012 10:33 AM
Maytag Dishwasher Control Panel kbgolliff Dishwasher Repair 0 11-20-2009 12:57 PM
Replace Maytag Dishwasher Control Panel retirednow Dishwasher Repair 0 10-14-2009 09:40 AM
Dishwasher touch panel or control board? Kebmike Dishwasher Repair 2 04-22-2008 06:44 PM
