dibergum
#1 Posted : Friday, November 27, 2009 4:35:27 AM(UTC)
dibergum
The dishwasher was responding sporadically to changes in the cycle and options. When I'd run the normal cycle, after several minutes into the cycle, the DW would cancel and drain.
I read in another forum entry about a similar problem, so after cleaning the ribbon connectors and checking that all the membrane switches were working properly with an ohmmeter, I ordered a replacement controller from this site.
Now when I install the new controller, I get an entirely different set of symptoms. It always starts in Instant wash, and I can only change cycles once to Normal. Then nothing works. I can't change any options. The display only shows one led segment.
I tried to activate the self test, and that doesn't do anything.
Putting my original controller back in, I get my original symptoms.
Do you think I got a bad replacement controller?
Dave
