Discuss
C5
 in
Dishwasher Repair
Having water delivery problems in 20 year old diswasher-only runs for about 3 minutes befor giving me the C5-
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » C5
  #1 (permalink)
Old 11-25-2009, 07:34 PM
matty2tan matty2tan is offline
Junior Member
matty2tan is on a distinguished road
Default C5
Model Number: 2200   Brand: GE   Age: More than 10 years
Having water delivery problems in 20 year old diswasher-only runs for about 3 minutes befor giving me the C5-not enough water,check water supply code. Pulled it out from under the cabinet, checked the supply line-good pressure. Had some high water pressure in the main lines (125PSI) but got it under control with a new pressure regulater valve. Pressure seems fine at the dishwasher inlet now-not high but very good. What are the chances that the water inlet valve is bad, and how hard is it to replace?
Thanks for your input....
Related Models
Hoover 2200 Frigidaire/refrigerator
Jenn-Air 22001 Surface Unit - Ddraft Ele
Hoover 2201 Frigidaire/refrigerator
Hoover 2204 Frigidaire/refrigerator
Whirlpool 2204W0A
Whirlpool 2204W1A
Whirlpool 2204W2A
Whirlpool 2204^0A
Whirlpool 2204^1A
Whirlpool 2204^2A
Amana 2208.100 Commercial Microwaves
Amana 2208.101 Commercial Microwaves
Amana 2208.A Commercial Microwaves
Hoover 2210
Amana 2210.000 Mwave - Family Size (60 Hz)
Jenn-Air 22112 Surface Unit - Ddraft Ele
Jenn-Air 22113 Surface Unit - Ddraft Ele
Jenn-Air 22114 Surface Unit - Ddraft Ele
Jenn-Air 22115 Surface Unit - Ddraft Ele
Jenn-Air 22116 Surface Unit - Ddraft Ele
Whirlpool 2212W0A
Whirlpool 2212W1A
Whirlpool 2212Z1A
Whirlpool 2212^0A
Whirlpool 2212^1A
Whirlpool 2214W0A
Whirlpool 2214W1A
Whirlpool 2214W2A
Whirlpool 2214^0A
Whirlpool 2214^1A
Whirlpool 2214^2A
Amana 2215S Room Air Conditioner
Whirlpool 2222W00
Whirlpool 2222W1A
Whirlpool 2222^00
Whirlpool 2222^1A
Whirlpool 2222^2A
Whirlpool 2224W0A
Whirlpool 2224W1A
Whirlpool 2224^0A
Whirlpool 2224^1A
Whirlpool 2228W00
Whirlpool 2228W10
Whirlpool 2228W20
Whirlpool 2228W30
Whirlpool 2228W40
Whirlpool 2228^00
Whirlpool 2228^10
Whirlpool 2228^20
Whirlpool 2228^30
Whirlpool 2228^40
Jenn-Air 22305 Surface Unit - Ddraft Ele
Whirlpool 2233W0A
Whirlpool 2233Z1A
Whirlpool 2233^0A
Whirlpool 2233^1A
Amana 2234.000 Mwave - Family Size (60 Hz)
Whirlpool 2234W0A
Whirlpool 2234W1A
Whirlpool 2234W2A
Whirlpool 2234^0A
Whirlpool 2234^1A
Whirlpool 2234^2A
Amana 2236.100 Commercial Microwaves
Amana 2236.101 Commercial Microwaves
Amana 2237.A Mwave - Family Size (60 Hz)
Amana 2238.000 Mwave - Family Size (60 Hz)
Amana 2238.001 Mwave - Family Size (60 Hz)
General Electric 22388L0 Electric range
General Electric 22388W0 Electric range
Whirlpool 2238W00
Whirlpool 2238W10
Whirlpool 2238W20
Whirlpool 2238^00
Whirlpool 2238^10
Whirlpool 2238^20
Amana 2239.A Mwave - Family Size (60 Hz)
Amana 2240.000 Mwave - Family Size (60 Hz)
Jenn-Air 22401 Surface Unit - Ddraft Ele
Jenn-Air 22402 Surf Cont Panel Unit - Ddft Ele
Jenn-Air 22403 Surf Cont Panel Unit - Ddft Ele
Jenn-Air 2240381 Surf Cont Panel Unit - Ddft Ele
Jenn-Air 22404 Surf Cont Panel Unit - Ddft Ele
Whirlpool 2242W00
Whirlpool 2242W1A
Whirlpool 2242W2A
Whirlpool 2242^00
Whirlpool 2242^1A
Whirlpool 2242^2A
Whirlpool 2244W0A
Whirlpool 2244W1A
Whirlpool 2244W2A
Whirlpool 2244^0A
Whirlpool 2244^1A
Whirlpool 2244^2A
Whirlpool 2248W00
Whirlpool 2248W10
Whirlpool 2248W20
Whirlpool 2248^00
Whirlpool 2248^10
Whirlpool 2248^20
Jenn-Air 2250ENC Walloven - Std Ele
Amana 2254.000 Mwave - Family Size (60 Hz)
Amana 2254.001 Mwave - Family Size (60 Hz)
Amana 2254.A Mwave - Family Size (60 Hz)
Jenn-Air 2255 Walloven - Std Ele
Jenn-Air 2255ENC Walloven - Std Ele
Hoover 2260
Whirlpool 2262W00
Whirlpool 2262W1A
Whirlpool 2262^00
Whirlpool 2262^1A
Whirlpool 2265W0A
Whirlpool 2265^0A
Hoover 2266 Frigidaire/refrigerator
Amana 2274.000 Mwave - Family Size (60 Hz)
Amana 2274.001 Mwave - Family Size (60 Hz)
Amana 2274.A Mwave - Family Size (60 Hz)
Whirlpool 2275W0A
Whirlpool 2275^0A
  #2 (permalink)
Old 11-26-2009, 02:44 AM
tommyboy84 tommyboy84 is offline
Member
tommyboy84 is on a distinguished road
Default Water supply or pump circulation problem?
An easy way to check your water supply to your dishwasher:
After 3 mins. from start up, open the door and visually check the bottom of your dishwasher.
If you have an insufficient amount of water, you'll want to replace the solenoid valve.
If you have a sufficient amount of water, the volute (intake) portion of the pump is most likely in need of some cleaning. The disposal is incorporated into the volute, see that it is clean and in proper working order. Be sure to inspect the pump impeller for necessary cleaning and in good condition. ( no cracks,etc.)
Any restrictions in any of those parts of the pump will certainly drop your unit's internal water circulation pressure.
Remember to unplug your unit before working on it.
On a 10 yr. old + dishwasher, you may want to consider a new replacement unit before you invest any funds into your old dishwasher - that has served you well!
The new energy saver units are so much more efficient, do a much better job at cleaning, and so much quieter.
Check recall info at:
General Electric Recalls Dishwashers Due to Fire Hazard
www.geappliancerecall.com.
Best to you.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
