Discuss
Control Lock
 in
Dishwasher Repair
THe Control Lock Indicator light is always lit. None of the selection buttons work. As the manual suggests, I did
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Control Lock
  #1 (permalink)
Old 03-05-2008, 02:54 PM
Donasking Donasking is offline
Junior Member
Donasking is on a distinguished road
Question Control Lock
Model Number: 665   Brand: Kenmore   Age: 5 - 10 years
THe Control Lock Indicator light is always lit. None of the selection buttons work. As the manual suggests, I did hold down the No Heat Dry pad for four seconds. This did not correct the problem. Why is this happening?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-06-2008, 02:11 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem caused by a one or more stuck pads on the key panel.
In order to provide the right part number for the console assembly for your dishwasher I need the complete model number and the color of the dishwasher.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 03-07-2008, 10:37 AM
Junior Member
Default
Note: Pressing any of the keys causes the control lock to flash three times but, nothing happens.
Model number is 665 and its' color is white.
  #4 (permalink)
Old 03-07-2008, 10:50 AM
Junior Member
Default
I think thgis is what you want as the full model number. 665.15951793
  #5 (permalink)
Old 03-07-2008, 04:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I also need the color of the control panel.
__________________
  #6 (permalink)
Old 03-08-2008, 06:08 AM
Junior Member
Default
It is white.
  #7 (permalink)
Old 03-10-2008, 11:45 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The part number for the membrane switch for your dishwasher is AP3096907.
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
lock-on light is on and cant re-set buddy16659 Dishwasher Repair 1 12-04-2008 05:57 AM
lock light tank duncan Oven Repair (including Ranges and Cooktops) 0 12-31-2007 09:29 AM
Washer will not lock pazjose Washer Repair 1 12-26-2007 03:29 PM
door lock gpc52 Washer Repair 1 10-29-2007 05:04 PM
Door will not lock hossross Washer Repair 0 08-25-2007 10:28 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
