Discuss
Whirlpool Quiet Partner III does not run
 in
Dishwasher Repair
My Whirpool Quiet Partner III will not run. The model is GU2548XTPS3. The "clean" LED flashes 7 times
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirlpool Quiet Partner III does not run
  #1 (permalink)
Old 03-04-2008, 07:44 PM
jimc_lmc jimc_lmc is offline
Junior Member
jimc_lmc is on a distinguished road
Default Whirlpool Quiet Partner III does not run
Model Number: GU2548XTPS3   Brand: Whirlpool   Age: 1 - 5 years
My Whirpool Quiet Partner III will not run. The model is GU2548XTPS3. The "clean" LED flashes 7 times slowly and pauses, then flashes 7 times and pauses, etc. When I set the options and press start, the "start" LED blinks 3 times fast and goes off. The other LEDs stay on and the "time" displays "--" and the "clean" LED flashes as described above (7 times, pause, etc.). After about a minute, the other option LEDs go out and only the "clean" blinks and pauses as described.
When I press "cancel" the timer shows "2" and I can hear the drain pump go on. Again, the "clean" LED blinks and pauses as above. After 2 minutes, the timer counts down and the pump stops.
No combination of cleaning cycle options seems to work. I have tried turning off the power to see if it would reset. The problem persisted.
Any assistance would be appreciated.
Jim
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-04-2008, 08:14 PM
bambiblaster bambiblaster is offline
Senior Expert
APP Volunteer
bambiblaster is on a distinguished road
Default
Your machine is telling you it had a problem reaching the proper wash temp.. alternate pushing no heat and the button next to it back and forth till all the console lights light up... that put into a test mode.. you can push the start button to advance thru the steps.. then use it again if it continues you will need to test the heater circuit. The is a tech sheet behing the lower toe panel with all tests..
  #3 (permalink)
Old 03-05-2008, 02:52 PM
Junior Member
Default
Thanks for the information. I ran the self-test, as you suggested. It went all the way through and all the LEDs went out, including "clean" which had been blinking. I ran a wash and it seemed to go all the way through the cycle. However, at the end, the "clean" LED reverted to the pattern of 7 blinks followed by a pause loop. I ran the self-test again and, again, I was able to run through a wash cycle. And, again, it ended with "clean" flashing 7 times followed by a pause. Any suggestions of where to go from here?
One thing we did notice is that the cycle seemed to take about 30 minutes, or so. I didn't time it precisely, in either case. Previously, it seemed like the wash cycle would take almots two hours. We had thought this was normal. Does that make sense or does it imply that there is another issue present?
I appreciate any advice you can offer.
Jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Confirming Part for Whirlpool Quiet Partner II brob Dishwasher Repair 12 11-11-2008 06:18 AM
Water Level Problems on whirlpool gold quiet partner III capt Dishwasher Repair 4 05-05-2008 09:36 PM
Whirlpool Gold Quiet Partner III bbrever Dishwasher Repair 3 01-08-2008 01:06 PM
Whirlpool Quiet Partner III Does Not Drain volant Dishwasher Repair 6 12-28-2007 03:17 AM
Whirlpool Gold Quiet Partner III - takes forever and gunk after cleaning dolemite44149 Dishwasher Repair 0 12-08-2007 03:12 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
