Discuss
Kenmore dishwasher motor won't pump water out
 in
Dishwasher Repair
I have an older Kenmore dishwasher circa 1992. At the start of the wash cycle, the pump should start to
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kenmore dishwasher motor won't pump water out
  #1 (permalink)
Old 03-04-2008, 09:28 AM
astro3ron astro3ron is offline
Junior Member
astro3ron is on a distinguished road
Default Kenmore dishwasher motor won't pump water out
Model Number: 587.1550590   Brand: -brand-   Age: More than 10 years
I have an older Kenmore dishwasher circa 1992. At the start of the wash cycle, the pump should start to pump out any left over water from before. But now I just hear a humming sound and then a click, like a relay shut something off. No circuit breakers have popped at the service panel. I can advance the timer knob to where it will allow hot water to come in, but the motor/pump won't kick in at the start of the cycle. Motor problem?? internal circuit overload?? Something hung up in the pump keeping the motor/pump from going?? Time for a new washer?? But the old ones seem to last much longer than the new ones...
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-04-2008, 07:27 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Remove the bottom panel and check for old water leak and rust over the motor. This is one of most common cause for motor damage.
Post your findings, please.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 03-04-2008, 08:24 PM
Junior Member
Default
Thanks, Gene. Checked for leaks but didn't see any. Wasn't sure how to see if I can turn the motor. From inside of washer, where/what would I have to remove to do this(with the power off of course)?? Didn't notice any other problems or odors. All the other cycles seem to work, water inlet, cooling fan etc, just no pump. Sounds like some relay has kicked in and then resets before I can try the cycle again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
noise from motor or pump? sleach1 Dishwasher Repair 15 11-10-2008 04:35 PM
Whirlpool Pump Motor BEK46 Dishwasher Repair 3 03-03-2008 09:32 PM
Kenmore dishwasher motor problem lgmccoy1 Dishwasher Repair 0 02-21-2008 09:34 AM
dishwasher motor/pump make a whinning noise tonyg5156 Dishwasher Repair 1 01-17-2008 03:48 PM
dishwasher instructions to replace complete motor and pump assembly needed Nancy Ramsey Dishwasher Repair 0 10-25-2007 01:22 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
