Discuss
GE Dishwasher making grinding noise
 in
Dishwasher Repair
This dishwasher hasn't been used for a couple of years and when it's turned on it makes a
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » GE Dishwasher making grinding noise
  #1 (permalink)
Old 03-03-2008, 02:33 PM
dhtuttle dhtuttle is offline
Junior Member
dhtuttle is on a distinguished road
Question GE Dishwasher making grinding noise
Model Number: GSD2800S45   Brand: GE   Age: 5 - 10 years
This dishwasher hasn't been used for a couple of years and when it's turned on it makes a grinding (rattling)noise in the lower right hand side during operation. Also, while the wash cycle is running, it will stop, beep, and Washer Arm Is Blocked message will luminate on the control panel. It turns off after I open then close the washer door. Any ideas???
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-04-2008, 02:25 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would do is check for possible water leak under the dishwasher due to the dishwasher has not been used for such long time and seals inside the pump could dry out.
Remove the bottom panel and check for water leak and/or water marks under the dishwasher.
Remove the inlet sump cover (#506 on the break down diagram) and the cap sump (#508 on the break down diagram) and check for a foreign objects inside the sump.
Check the lower spray arm for blocked wash holes.
Post your findings.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchen Aid Dishwasher wont run, making loud buzzing noise. Please help! jmoriarty@bellsouth.net Dishwasher Repair 0 02-22-2008 04:53 PM
Dishwasher grinding noise tmurphy1111 Dishwasher Repair 1 02-18-2008 06:11 PM
Ice maker making a grinding sound ImSR Refrigerator & Freezer Repair 1 02-07-2008 05:51 PM
Estate Dyer making grinding noise gsaldana71 Dryer Repair 1 12-28-2007 01:17 PM
Grinding noise from washer jreynolds Washer Repair 2 12-27-2007 03:05 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
