Discuss
Countdown timer sticks
 in
Dishwasher Repair
The countdown timer on my Bosch dishwasher stops at 1 minute and continues to run. Opening door shows soapy water
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Countdown timer sticks
  #1 (permalink)
Old 03-03-2008, 09:57 AM
FJ Pierce FJ Pierce is offline
Junior Member
FJ Pierce is on a distinguished road
Default Countdown timer sticks
Model Number: SHU5306UC/U06 (FD7905)   Brand: Bosch   Age: 5 - 10 years
The countdown timer on my Bosch dishwasher stops at 1 minute and continues to run. Opening door shows soapy water in bottom of washer. Closing door resets the timer to 13 minutes which then counts down to 1 and then continues to run. Will replacing the control module (shu 53/68) fix the problem? Any Suggestions?
FJ Pierce
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-04-2008, 08:20 PM
bambiblaster bambiblaster is offline
Senior Expert
APP Volunteer
bambiblaster is on a distinguished road
Default
That has been the most common culprit on Bosch when the unit hangs up...
  #3 (permalink)
Old 03-05-2008, 02:14 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
As bambiblaster said, it has been one of most common problem caused by a bad control module. Replacing the control module should fix it.
- The part number for the control module is AP2802870
Here are the break down diagrams for the Bosch dishwasher Model SHU5306 UC/06 (FD 7705-7912)
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
timer does not run scotthelland Dryer Repair 0 02-15-2008 02:11 PM
GE timer eddiedanner Dryer Repair 0 02-01-2008 01:19 PM
jenn air trash compactor sticks rbern007 Trash Compactor Repair 3 10-11-2007 11:34 PM
Bosch won't countdown to zero StratLou Dishwasher Repair 4 09-04-2007 07:28 AM
Countdown Display INOP, Washer cycles normally Julia Dishwasher Repair 0 08-20-2007 10:03 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
