| » KitchenAid DW won't wash |
Model Number: KUDP01ILWH3 Brand: Kitchen Aid Age: 5 - 10 years
This problem might have been addressed in the forum already, but I'm not quite sure if what I've got is exactly the same as a previous problem...
RE a 5yo KitchenAid KUDP01ILWH3. Stopped mid-cycle last night and clean light was on in AM but cycle hadn't completed. Cancelled and unit drained. Started again this afternoon, water filled in tub, unit hummed and clicked. Water heating light came on and water got steamed. Hums and clicks continued. Finally hit cancel, unit drained and lights went off. Read thru forum entries and it seems like the motor is bad. But thermal fuse might be a candidate, too. What do you think? Ads By Google Related Models |
Replacement parts for WHIRLPOOL KUDP01ILWH3 | AppliancePartsPros.com Here is the tech sheet http://www.servicematters.com/docs/w...%208537797.pdf Read thru forum entries and it seems like the motor is bad. But thermal fuse might be a candidate, too. Will not be the thermal fuse as it kills power to the unit. Could be a bad motor or a jammed motor. Open it up and make sure nothing is jammed in the chopper and impeller.
__________________
| Display Modes | |
| Kitchenaid wash arm assembly will not thread back on to hub | evelynasmith | Dishwasher Repair | 0 | 10-27-2009 06:52 AM |
| When wash is complete the machine stay on agitate and won't allow a new wash cycle | Trofytrout | Washer Repair | 1 | 07-07-2009 01:34 PM |
| KitchenAid Long wash cycle | bisco | Dishwasher Repair | 4 | 03-29-2009 08:18 PM |
| Kitchenaid fills but doesn't wash.... | wotan2525 | Dishwasher Repair | 24 | 01-30-2009 02:47 PM |
| Washer not pumping at the end of wash but will pump on spin and lite wash. | rathbonr | Washer Repair | 0 | 07-16-2008 11:45 AM |
