Discuss
Kenmore blown fuse
 in
Dishwasher Repair
I need a fuse part number G4AM1102. Where can I purchase one?
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kenmore blown fuse
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 03-02-2008, 04:51 PM
johnr johnr is offline
Junior Member
johnr is on a distinguished road
Default Kenmore blown fuse
Model Number: 665.17379301   Brand: Kenmore   Age: 1 - 5 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-03-2008, 04:07 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Where did you get this part number? It does not look like a valid Whirlpool part number.
What exactly is wrong with your dishwasher?
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 03-03-2008, 04:20 PM
Junior Member
Default
Gene, I removed the part from my Kenmore Model Number: 665.17379301 . Tha is the number on the part I removed. John
  #4 (permalink)
Old 03-03-2008, 04:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm assuming you are looking for the thermal fuse
- The part number for the thermal fuse is AP3178588
__________________
  #5 (permalink)
Old 03-03-2008, 05:18 PM
Junior Member
Default
Thank you Gene, I was able to find the descrete component part number G4A01098C for $1.26. I will need to solder it into the holder, but I feel confident I have the correcly rated part. Thanks, John
  #6 (permalink)
Old 03-03-2008, 08:30 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Be very careful soldering it. This is a thermal fuse with about 100°C or less temperature.
__________________
  #7 (permalink)
Old 08-25-2008, 10:15 PM
JasonParker JasonParker is offline
Junior Member
JasonParker is on a distinguished road
Default Finding Part G4A01098C
JohnR,
I too have a blown G4AM1102. I see you traced the fuse itself and saved some dough. Can you tell me where you found it? All the places I've checked so far have minimum orders far in excess of the $14.95 advertised by appliancepartspros.com.
Thanks,
-Jason
  #8 (permalink)
Old 08-26-2008, 07:46 AM
libertyappl libertyappl is offline
Senior Member
libertyappl is on a distinguished road
Default
I wouldn't recommend the soldering solution made above, the part Gene suggested is the one approved for this dishwasher and the other one could possibly burn the guys house down if he's not careful! And that could cost him a lot more than $14.95 for using the correct part.
Nat
  #9 (permalink)
Old 08-26-2008, 08:49 AM
Junior Member
Default
As an engineer, my second and fourth tendencies are to be conservative and safe, so any risk of fire should be carefully considered.
Gene's excellent advice, though, is aimed at not overheating the thermal fuse and destroying it. Since it's a safety cutoff device, a very real scenario is that the thermal fuse gets triggered open by the heat from soldering and the dishwasher doesn't work after going to the trouble of doing the repair. Gene seems to be trying to save John the frustration of wasting his time and having to go get another thermal fuse.
The thermal fuse manufacturer's datasheet does say that the fuse can become permanently closed again if it's exposed to temperatures greater than 140-C for an extended period of time. In short, if your sodlering skills aren't fairly well developed, don't attempt this repair. If you can solder, you're probably already familiar with the risk of cooking the soldered part and know to be crisp and fast with your work.
Anyone with concerns should call a qualified service technician.
In my case, the "stock" part isn't a direct replacement and comes with alot of doodads that aren't on my unit. It makes more sense to just replace the thermal fuse.
P.S. I found the part at a local electrical/electronics shop for a buck and change.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Where's the thermal fuse? deburrito Dryer Repair 10 08-21-2008 06:52 PM
Fuse burn out robertiogawa Washer Repair 1 01-27-2008 12:07 PM
Blown Fuse question Davejb Dishwasher Repair 1 01-13-2008 02:41 AM
Blown fuse Scottpr Dryer Repair 1 11-26-2007 01:55 PM
2nd blown thermal fuse??? Cari Dryer Repair 2 11-25-2007 04:54 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
