| » Replacing Door on Bosch Dishwasher |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: SHU9955 Brand: Bosch Age: 1 - 5 years
My Husband unscrewed the front pannel to tighten the handle which was falling off. When he did 2 white plastic pieces came out. I think they are called door guards. Does anyone know how to put them back in or know where they go? I can't seem to find a diagram anywhere. Also, is it normal for the white insulation on the inside to be a bit moldy? Yuk!! Thanks for any help...
Hi Tracy,
Slide them back in over the hinge, lining up the door guard square tab with the hinge lever square notch. Gene.
__________________
Professional appliance repair services in Orange County, California. |
Hello
I have a loose handle on my Bosch DW - only about 3 yrs old. Is it necessary to remove the whole inside panel to tighten it? What pitfalls are there - like springs or other things that will fall out? Is there a seal than will be difficult to reset? Thanks, TED GROAT |
Hi Ted,
What is the complete model number of the dishwasher? Gene.
__________________
You can find the model number on the right side of the door or behind the bottom panel.
__________________
Professional appliance repair services in Orange County, California. Last edited by Gene : 06-28-2008 at 06:42 PM. Reason: missed word |
To remove the outer door, open the door and remove the T-20 Torx screws located on each side of the inner stainless door.
Return the door back to its upright position, and bring the bottom of the door panel out toward you, then slide the top of the panel down and out from under the fascia panel. As the outer door is being removed, the left or right door guards may shift or fall out of place. To reposition them, slide them back in over the hinge, lining up the door guard square tab with the hinge lever square notch. Please note: door guards must be in place before reinstalling the door panel. Tighten the screws holding the door handle. Assemble in the reverse order. Longer drying time for a plastic dishes is normal due to their porous surface. Gene.
__________________
| Display Modes | |
| Bosch Soap Door Doesn't Open | jmccs | Dishwasher Repair | 7 | 08-06-2008 05:14 PM |
| Replacing door on Jenn-Air Microwave | amytcb | Microwave Repair | 3 | 05-23-2008 01:13 PM |
| Door handle needs replacing | halfagram | Microwave Repair | 0 | 01-25-2008 11:14 AM |
| Replacing Oven Door Glass | campster | Oven Repair (including Ranges and Cooktops) | 1 | 01-24-2008 01:47 PM |
| Replacing Drain Hose on Bosch Dishwasher | Lorenzo | Dishwasher Repair | 2 | 08-07-2007 06:24 AM |
