Discuss
Lower arm seems to work, middle & upper not working
 in
Dishwasher Repair
Hi (and thanks!). I've got a Whirlpool quiet partner 1 dishwasher that fairly recently stopped getting the upper rack
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Lower arm seems to work, middle & upper not working
  #1 (permalink)
Old 02-28-2008, 10:22 AM
n3jhv n3jhv is offline
Junior Member
n3jhv is on a distinguished road
Question Lower arm seems to work, middle & upper not working
Model Number: DU1050XTPB3   Brand: Whirlpool   Age: Less than 1 year
Hi (and thanks!). I've got a Whirlpool quiet partner 1 dishwasher that fairly recently stopped getting the upper rack clean. Lower rack seems to clean OK. I've pulled out the middle spinner to verify it isn' full of stuff.
#1: How do I defeat the door interlocks so I can observe IF all the arms are getting water?
#2: If the lower arms spins, but the middle doesn't, and the feed tubes are not obstructed, any suggestions?
I'm wondering if it's the seal between the middle spinner and the feed point on the back wall of the dishwasher, but I don't see any evidence of a gasket or a way to seal them tightly-could I have pressure loss there? If I can at least observe them working, I may be able to spot something.
Thanks again!
Sid
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-03-2008, 05:45 PM
Junior Member
Default
anyone? ttt
  #3 (permalink)
Old 11-06-2008, 04:06 PM
Junior Member
Default
OK, seemed to fix itself for a bit, now it's back. Removed bottom arm, feed tube running up the back, took the 4 torx screws off, took off the filter, cleaned out the gunk (not too much) that was under there, put it back together. Feed tubes also not obstructed.
Any suggestions???
  #4 (permalink)
Old 11-07-2008, 07:12 AM
richappy richappy is online now
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Remove the half round pump cover on the pump base and sponge out all the water. Turn the water off to the dishwasher, turn the dishwasher on, and verify the chopper turns by opening the door briefly. If turning, but the screen is clogged, replace it and the check valve in the bottom of the pump base next to the chopper.
Parts needed, chopper AP3039186, check valve, AP3152971
__________________
  #5 (permalink)
Old 11-07-2008, 07:41 AM
Junior Member
Default
Thanks much Rich!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maytag dual oven, lower oven won't work curt6 Oven Repair (including Ranges and Cooktops) 4 11-04-2008 01:26 PM
Whirlpool upper agitator not working Roger-dodger Washer Repair 1 01-22-2008 09:06 PM
Americana Range with upper and lower oven effinsyv Oven Repair (including Ranges and Cooktops) 1 12-18-2007 07:11 AM
upper oven not working drembo Oven Repair (including Ranges and Cooktops) 0 11-03-2007 10:13 AM
upper and lower burners not consistent artkat Oven Repair (including Ranges and Cooktops) 0 09-28-2007 03:29 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
