bamafanjay
#1 Posted : Thursday, November 12, 2009 3:03:00 PM(UTC)
bamafanjay
dishwasher gets stuck in heat delay twice. at 7oclock position and before drying cycle. water heater is set at 130. i also put water heater at 160 and it still had heat delays. it will not advance unless you turn timer one click. this washer has three temp sensors dont know if heat element could be a cause. if you open door in drying cycle air is warm but not as warm as i think it should be. dishes are never dry we add rinse aid but still no effect.
#2 Posted : Friday, November 13, 2009 2:21:14 AM(UTC)
Replacement parts for FRG FDB635RBQ1 | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/p...df/Kinston/154441701.pdf
I would check the following
Hi-limit thermostat should be 0 ohms
Heater should be around 15 ohms
maddog8212
#3 Posted : Monday, February 22, 2010 12:04:30 PM(UTC)
maddog8212
I have the EXACT same problem with a dishwasher that sticks at 7 o'clock and at 10 o'clock before the dryer cycle. Would love to know the resolution of your problem, as mine is unresolved.
Appliance Repairmen have (1) replaced timer, (2) replaced thermostats 154227805 and 154227808, and (3) fixed a loose wire on thermostat. $250. Was either of these the High Temp Thermostat? Do I have two, or three, thermostats?
maddog8212
#4 Posted : Sunday, March 14, 2010 7:07:43 AM(UTC)
maddog8212
http://forum.appliancepartspros...ermostat.html#post197635
Frigidaire dishwasher where timer would not advance on heating cycles.
Hi limit thermostat was out.
$20 part replaced to 10 minutes, and dishwasher works on all cycles.
