| » Whirlpool Pump Motor |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: GU1500XTLQ2 Brand: Whirlpool Age: 1 - 5 years
Dishwasher became very much louder during washing then finally quit pumping water to the spray arms. Fills and drains OK but does not pump up. Just hums! This seems to be a frequent failure for Whirlpools.
Whirlpool offered me 15% rebate if I purchase another WHirlpool family of dishwashers. Is the pump motor the likely problem here? IS this is cost effective replacement for a 4 year old unit? |
Sounds like the seals in the pump stuck together.
This is very common problem for most of dishwashers, even the most expensive. I do not think you need to replace the motor, just install the new impeller kit. The volute seal has to be replaced too. The cost of repair is less then $30.00 The dishwasher has to be removed from the cabinet for this job. You can find the complete instructions in the tech sheets behind the bottom panel. - The part number for the impeller kit is AP3738238 - The part number for the volute seal is AP3039198 Here are the break down diagrams for the Whirlpool dishwasher Model GU1500XTLQ2 Gene.
__________________
Professional appliance repair services in Orange County, California. |
Gene: Thanks for the help. It turns out it was the motor - took it out and the armature was fried. I managed to remove it without removing the entire assemply. Had to use a flex extension on a ratchet to get the attaching bolt out. Saved a few hours work I suspect. Got your replacement within 2 days and happily all is back working well again.
I'm glad you were able to fix it.
__________________
| Display Modes | |
| Pump/ Motor removal | dudedudeness | Dishwasher Repair | 4 | 05-17-2008 01:48 PM |
| noise from motor or pump? | sleach1 | Dishwasher Repair | 11 | 05-17-2008 06:03 AM |
| pump/motor replacement | willbill | Dishwasher Repair | 1 | 12-04-2007 10:01 PM |
| How can I seperate the motor from the pump? | Sandman | Washer Repair | 3 | 08-29-2007 08:41 AM |
| pump and motor noise | Mike G. Siano | Washer Repair | 0 | 08-17-2007 09:04 AM |
