Discuss
Dishwasher leaking while off
 in
Dishwasher Repair
The dishwasher has a hose on the inside on the left. I don't know what the hose is for
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher leaking while off
  #1 (permalink)
Old 02-27-2008, 11:42 AM
jwcyre jwcyre is offline
Junior Member
jwcyre is on a distinguished road
Default Dishwasher leaking while off
Model Number: MDB5000AWB   Brand: Maytag   Age: 1 - 5 years
The dishwasher has a hose on the inside on the left. I don't know what the hose is for but it is slowly leaking water. The water then builds up in the dishwasher and eventually leaks on the floor. This has happened twice only while the dishwasher is off. The second time it happened the water was turned off to the dishwasher. I can only assume that it is backing up from the garbage disposal, but I really have no idea. The garbage disposal itself is not backed up.
So does anyone know what might be causing this?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-27-2008, 04:09 PM
Junior Member
Default
After looking at the parts diagrams it looks like it is the leaking out of the water injector (part 5 on diagram 6). What is the purpose of this and what water source is it hooked up to? I have a feeling that the valve is bad. Any thoughts?
  #3 (permalink)
Old 02-28-2008, 01:44 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the water inlet valve (#2 on the tub break down diagram) is stuck open.
Possible the water shut off valve for the dishwasher is not working properly which caused the overflowing the second time. It has to be checked by a plumber.
- The part number for the dishwasher water valve is AP178686
Here are the break down diagrams for the Maytag dishwasher Model MDB5000AWB
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
leaking dishwasher verne k Dishwasher Repair 6 09-15-2008 09:03 AM
Dishwasher leaking Jet Dry rob g Dishwasher Repair 0 01-26-2008 03:48 PM
dishwasher leaking marshalllandscape Dishwasher Repair 1 12-13-2007 09:28 PM
Leaking Dishwasher warrenjr Dishwasher Repair 1 12-03-2007 06:16 PM
Dishwasher leaking jeremiah Dishwasher Repair 3 11-14-2007 12:02 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
