Discuss
Maytag Neptune LR code
 in
Dishwasher Repair
Hi, My maytag MAH6500MWW won't spin. There is a burn register on the control board. I am not sure
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Maytag Neptune LR code
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-26-2008, 07:35 AM
sonny_p sonny_p is offline
Junior Member
sonny_p is on a distinguished road
Default Maytag Neptune LR code
Model Number: MAH6500MWW   Brand: Maytag   Age: 1 - 5 years
My maytag MAH6500MWW won't spin. There is a burn register on the control board. I am not sure this is the same infamous R11 & Q6 problem. I am going to order a new board but not sure if I have to order the door switch motor or something else to prevent it from burning again.
Thanks for all the help.
Sonny
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-26-2008, 05:20 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Sonny,
I do not thing you have to replace anything else besides the control board.
Maytag redesign the door latch and there is no more a wax motor used on your model.
- The part number for the main control board is AP3449382
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 02-27-2008, 08:21 PM
Junior Member
Default
Hi Gene,
Thanks for your response. I did ordered and received the new control board today. However, after installed the new control board and run a Quick Service Cycle test, it ended with the same LR code. I did open the back panel and can tell the motor does not even turn during the tumbling phase at all. It seems that the motor is really locked as indicated by the error code. Is there any other test, procedure that I can do? For your reference, the register R104 was the one that burn from the old control board.
Please help !!!!
Sonny
  #4 (permalink)
Old 02-28-2008, 10:56 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Sonny,
Did you check the motor control board?
Remove the cover and visually inspect the board. If you did not see anything wrong then perform test as described in the tech sheets.
__________________
  #5 (permalink)
Old 02-28-2008, 12:16 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I found a new information in the Maytag technical bulletin which may help to solve the problem with your washer.
__________________
  #6 (permalink)
Old 02-28-2008, 01:47 PM
Junior Member
Default
Hi Gene,
Thank you very much for the information. I will try it tonight and hope that it will fix my problem.
Thanks,
Sonny
  #7 (permalink)
Old 02-28-2008, 02:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Keep me updated, please.
__________________
  #8 (permalink)
Old 02-29-2008, 07:16 AM
Junior Member
Default
Hi Gene,
I did try the procedure described in the Technical bulletin but still could not get the motor to turn or spin. I then remove the Motor Control Board to check as you have suggested in earlier post. I could not see any visible damage or burn mark. Since I have access to the Motor control board, I then try the Motor Control Board Output test, where you disconnect the JP4 connector. I follow the test procedure and the motor DID SPIN at the end of the test. However, when I reconnect the JP4 connector, the motor still does not turn or spin during either the SPIN or Quick Service test.
I hope you have some idea for me to try. Your help is greatly appreciate.
Thanks,
Sonny
  #9 (permalink)
Old 02-29-2008, 11:17 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Sonny,
Even the test with the JP4 connector did not show the problem, I still believe the motor control board has to be replaced.
To find out the right part number for the motor control board I need the serial number of the washer and I need you to verify the last three letters of the model number.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Neptune starts then stops in 5 sec EddieM Washer Repair 3 02-16-2008 09:38 AM
Maytag Neptune washer ccseeley Washer Repair 5 01-31-2008 12:51 PM
Maytag Neptune Help Needed - LR code vtcyclist Washer Repair 2 11-14-2007 09:59 AM
Maytag Neptune LarryC Washer Repair 2 09-29-2007 07:56 PM
Maytag Neptune Washer utep42 Washer Repair 1 08-31-2007 03:59 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
