Discuss
Leaking Dishwasher
 in
Dishwasher Repair
There is an intermittent leak on the right side of the door under the unit. I installed a foam strip
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Leaking Dishwasher
  #1 (permalink)
Old 11-09-2009, 05:49 PM
Junior Member
macnlrc is on a distinguished road
Default Leaking Dishwasher
Model Number: GU980SCGQ2   Brand: Whirlpool   Age: More than 10 years
There is an intermittent leak on the right side of the door under the unit. I installed a foam strip on top of the existing door gasket and the leak apparently stopped. Then, I purchased a new door gasket and the leak started again. I next tried to insert the foam strip behind the gasket and it still leaks. The leak occurs at the second wash cycle (only slow dripping during the first wash). T^he leak seems to "splash" leading me to think that the lower wash arm has something to do with it. I removed the two bottom panels and note that the leak originates from the hinge area. I cannot see if there is a crack in the tub but since it is an intermittent leak, probably not. All of the other functions of the washer work just fine. Any thoughts will be most helpful before I invest in a new dishwasher.
Ads By Google
Related Models
Whirlpool GU980SCGQ2
Whirlpool GU980SCGQ3
Whirlpool GU980SCGS1
Whirlpool GU980SCGS2
Whirlpool GU980SCGS3
Whirlpool GU980SCGT2
Whirlpool GU980SCGT3
Whirlpool GU980SCGZ0
Whirlpool GU980SCGZ1
Whirlpool GU980SCGZ2
Maytag GV1110PRW Range - F/s Std Gas
International GV1226NXEW Freezer - Vertical
International GV1726NXEW Freezer - Vertical
Hoover GV3177WUA Range - F/s Std Gas
Hoover GV3177WUA5 Range - F/s Std Gas
Hoover GV3177WUW Range - F/s Std Gas
Hoover GV3177WUW5 Range - F/s Std Gas
Maytag GV3277XUA Range - F/s Std Gas
Maytag GV3277XUW Range - F/s Std Gas
Hoover GV3531WUA Range - F/s Std Ele
Hoover GV3531WUW Range - F/s Std Ele
Whirlpool GVW9959KL0
Whirlpool GVW9959KL1
Whirlpool GVW9959KL2
Whirlpool GVW9959KL3 Automatic Washer
Whirlpool GVW9959KQ0
Whirlpool GVW9959KQ1
Whirlpool GVW9959KQ2
Whirlpool GVW9959KQ3 Automatic Washer
Whirlpool GVW9959KT0
Whirlpool GVW9959KT1
Whirlpool GVW9959KT2
Whirlpool GVW9959KT3 Automatic Washer
Maytag GW18F1 Washer - Top Loading
Maytag GW18F1A Washer - Top Loading
Maytag GW18F1H Washer - Top Loading
Maytag GW18F1W Washer - Top Loading
Maytag GW18F2 Washer - Top Loading
Maytag GW18F2A Washer - Top Loading
Maytag GW18F2H Washer - Top Loading
Maytag GW18F2W Washer - Top Loading
Maytag GW18G1 Washer - Top Loading
Maytag GW18G100 Washer - Top Loading
Maytag GW18G124 Washer - Top Loading
Maytag GW18G125 Washer - Top Loading
Maytag GW18G1A Washer - Top Loading
Maytag GW18G1HW Washer - Top Loading
Maytag GW18G1WW Washer - Top Loading
Maytag GW20F6 Washer - Top Loading
Maytag GW20F600 Washer - Top Loading
Maytag GW20F624 Washer - Top Loading
Maytag GW20F625 Washer - Top Loading
Maytag GW20F6A Washer - Top Loading
Maytag GW20F6H Washer - Top Loading
Maytag GW20F6W Washer - Top Loading
Frigidaire GW30SPEA2 Wwh(v1) / Electric Range
Frigidaire GW30SPED1 Wwh(v2) / Electric Range
Frigidaire GW30SPEW1 Wwh(v1) / Electric Range
Frigidaire GW30SPEW2 Wwh(v2) / Electric Range
Whirlpool GW395LEGB0
Whirlpool GW395LEGB1
Whirlpool GW395LEGB3
Whirlpool GW395LEGB4
Whirlpool GW395LEGB5
Whirlpool GW395LEGB6
Whirlpool GW395LEGQ0
Whirlpool GW395LEGQ1
Whirlpool GW395LEGQ3
Whirlpool GW395LEGQ4
Whirlpool GW395LEGQ5
Whirlpool GW395LEGQ6
Whirlpool GW395LEGT3
Whirlpool GW395LEGT4
Whirlpool GW395LEGT5
Whirlpool GW395LEGT6
Whirlpool GW395LEGZ0
Whirlpool GW395LEGZ1
Whirlpool GW395LEGZ3
Whirlpool GW395LEPB00 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB05 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ00 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ05 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS00 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS05 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT00 30" Slide - in Gas Oven Non - Convect
Whirlpool GW395LEPT01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT05 30" Slide - in Gas Oven Non - Conv
Maytag GWC202 Dishwasher - Convertible
Maytag GWC204 Dishwasher - Convertible
General Electric GWR03AAMABB Refrigerator
Gibson GWS1149AS0 Washer - Gibson
Gibson GWS1149AS1 Washer - Gibson
Gibson GWS1339CS0 Gibson/washer
Gibson GWS1339CS1 Gibson/washer
Gibson GWS1749AS0 Washer - Gibson
Gibson GWS1749AS1 Washer - Gibson
Gibson GWS1749CS0 Gibson/washer
Frigidaire GWS223RFS0 Gib(v0) / Washer
Frigidaire GWS223RFS1 Gib(v0) / Washer
Frigidaire GWS223RHS0 Gib(v0) / Washer
Frigidaire GWS223RHS1
Frigidaire GWS445RFS0 Gib(v0) / Washer
Frigidaire GWS445RFS1 Gib(v1)
Frigidaire GWS445RFS2 Gib(v0) / Washer
Frigidaire GWS445RHS0 Gib(v0) / Washer
  #2 (permalink)
Old 11-10-2009, 02:51 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL GU980SCGQ2 | AppliancePartsPros.com
Check the spray arm to be sure it does not have a crack. Also that all the holes are open. I find the easiest way to clean the holes is with a tweezers part way through a cycle when everything is wet. Sometimes the water can spray out at a weird angle and cause a leak.
Clean the area in the tub just under the door sometimes crud can collect here and cause problems.
Make sure the barrier Item 21 in Section 1 is OK
Check the deflector Item 12 in Section 6
Check the float Item 32 Section 6, sometimes crud can collect here and cause a drip. Note this would be behind the kick plate.
Check that the unit is installed level or slightly leaning to the back.
I am assuming that the unit drains correctly and the unit is not overfilling.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dishwasher leaking poof3184 Dishwasher Repair 0 08-10-2009 12:09 PM
GE Dishwasher leaking _Joe_ Dishwasher Repair 4 08-06-2009 04:43 PM
GE Dishwasher Leaking leland48 Dishwasher Repair 2 04-15-2009 12:31 PM
GE dishwasher leaking Chuck Hamby Dishwasher Repair 1 11-09-2008 12:48 PM
Dishwasher leaking jeremiah Dishwasher Repair 3 11-14-2007 11:02 AM
