| » bosch shu3036 or 3032 level switch |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: shu3036uc12 Brand: Bosch Age: 1 - 5 years
float switch lever seems to have a disintegrating styrofoam block under it not allowing water into unit. Is that block supposed to be there?
Hi Dennis,
I do not think it suppose to be there in such position. I would remove it. Here are the break down diagrams for the Bosch dishwasher Model SHU3036 UC/12 (FD 8003-) Gene.
__________________
Professional appliance repair services in Orange County, California. |
Dennis
Is this the styrofoam float that is under a grey plastic pivot arm that raises the red rod to activate the base water safety system. When the float raises the water is shut off and the drain will run. Mice like to eat this that may be the reason for the damge. |
| Display Modes | |
| water level switch install | LSUKixAss1 | Washer Repair | 2 | 01-30-2008 03:34 PM |
| water level | Jerome Pikus | Washer Repair | 1 | 12-16-2007 02:29 PM |
| Bosch On/Off Button&Switch Replacement | dkh | Dishwasher Repair | 3 | 12-13-2007 08:01 PM |
| infinite switch wiring change from 6 wires to 5 wire switch | wiedemanndds | Oven Repair (including Ranges and Cooktops) | 3 | 12-06-2007 12:45 PM |
| Maytag Washer Inlet valve - water level switch | reisman | Washer Repair | 0 | 10-23-2007 08:36 PM |
