Discuss
Draining continuosly
 in
Dishwasher Repair
Dishwasher is draining water from the tub all the time. Therefore. there isn't enough water in the tub to
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Draining continuosly
  #1 (permalink)
Old 02-25-2008, 11:43 AM
cblu007 cblu007 is offline
Junior Member
cblu007 is on a distinguished road
Default Draining continuosly
Model Number: 665.11073352   Brand: Kenmore   Age: 5 - 10 years
Dishwasher is draining water from the tub all the time. Therefore. there isn't enough water in the tub to supply the pump with enough water to wash the dishes. Arms are not moving. Please help. Float in the tub to prevent overflow seems to be working fine. Tub will not fill up.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-26-2008, 08:06 PM
roycreamer roycreamer is offline
Expert
APP Volunteer
roycreamer is on a distinguished road
Default
make sure some part of the drain hose is as high as the top of the dishwasher...
__________________
roy
the appliance whisperer
  #3 (permalink)
Old 02-27-2008, 09:09 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Check your model #, it will not work. Pull your drain hose and verify it is pumping out while it is supposed to be washing. If so, you may have an electronic module problem.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
DW not draining/starting fakhar11 Dishwasher Repair 0 01-09-2008 01:15 PM
not draining Belkey Washer Repair 1 12-09-2007 09:15 PM
Dishwasher not draining KMan105 Dishwasher Repair 1 11-28-2007 10:13 PM
Draining problem dgold13 Dishwasher Repair 0 11-13-2007 08:42 AM
no draining after washing. luirod563 Washer Repair 4 10-12-2007 09:38 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
