Discuss
Confirming Part for Whirlpool Quiet Partner II
 in
Dishwasher Repair
Trying to confirm that I have found the correct part for my dishwasher before ordering it. I read a number
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Confirming Part for Whirlpool Quiet Partner II
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-25-2008, 08:08 AM
brob brob is offline
Junior Member
brob is on a distinguished road
Default Confirming Part for Whirlpool Quiet Partner II
Brand: Whirlpool   Age: 1 - 5 years
I read a number of other posts and ran the tests. I have (non-professionally, of course) determined that my drain pump is to blame for my problems.
I have a Whirlpool Quiet Partner II. The numbers that I find on the inner part of the unit that I believe one or the other is the model number are as follows.
Imperial / DUL200PKQ1 / 8268470
Trying to determine if this ( Part Number: AP3133590 ) is the correct part that I need to order.
Please help.
I love the magic of the internet!
Thank you!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-25-2008, 07:14 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
What is the original problem with your dishwasher?
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 02-25-2008, 07:40 PM
Junior Member
Default
Dishes are not getting rinsed properly causing spotting and film. Water comes into the system just fine, but does not drain properly at the end of the cycle. Once the wash is completed, there is standing water in the bottom of the tub.
  #4 (permalink)
Old 02-25-2008, 08:27 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The first thing I would check is the air gap on top of the sink (if any).
Remove the cover from the air gap, remove the top piece and check for clog.
Remove the drain hose from the air gap or wherever it is connected, put the end of the drain hose in a bucket, run the drain cycle and look for any foreign objects coming out.
If this is not the issue, then remove the bottom panel, remove water from the dishwasher, disconnect the drain hose from the check valve (#15 on the pump & motor break down diagram) and remove the check valve (turn CCW).
Inspect the check valve for a clog.
Here are the break down diagrams for the Whirlpool dishwasher Model DUL200PKQ1
P.S. There is no drain pump in your dishwasher.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water Level Problems on whirlpool gold quiet partner III capt Dishwasher Repair 4 05-05-2008 08:36 PM
Whirlpool Gold Quiet Partner III bbrever Dishwasher Repair 3 01-08-2008 12:06 PM
Whirlpool Quiet Partner III Does Not Drain volant Dishwasher Repair 6 12-28-2007 02:17 AM
Whirlpool Gold Quiet Partner III - takes forever and gunk after cleaning dolemite44149 Dishwasher Repair 0 12-08-2007 02:12 PM
Whirlpool Quiet Parnter II Locked bigbalbossa Dishwasher Repair 8 10-26-2007 01:37 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
