Discuss
white powdery film on some sishes
 in
Dishwasher Repair
I have a white powdery film on some dishes.I have been using a gel soap..I tried to change
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » white powdery film on some sishes
  #1 (permalink)
Old 11-06-2009, 09:22 PM
valor111 valor111 is offline
Junior Member
valor111 is on a distinguished road
Default white powdery film on some sishes
Brand: Kitchen Aid   Age: 1 - 5 years
I have a white powdery film on some dishes.I have been using a gel soap..I tried to change soaps and it still left the white powder.What could be causing this?
  #2 (permalink)
Old 11-07-2009, 08:12 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Sounds like hard water.
Here is a link, check out #28
http://www.applianceaid.com/dish.html
Has it always done this or is it something that just started recently?
Is it just the film or is it also food particles?
Has anything changed in the house plumbing lately re: new water softener etc.?
When you tried a different soap, did you try a granulated type?
Note: In my opinion this is still the best detergent.
Have you tried using less detergent?
Is the water entering the unit a minimum of 120 degrees?
I would also try emptying some water out of your hot water tank.
Use either the drain or the over pressure release. Let it run till it is clear.
Minerals etc. can collect in the bottom of the tank.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
White film on dishes bese05 Dishwasher Repair 1 12-12-2008 08:43 PM
White film inside door; glasses not clean ddill Dishwasher Repair 3 11-27-2008 04:39 AM
