Discuss
dishwasher won't start or run unless I apply pressure to door (even with tight closur
 in
Dishwasher Repair
Same problem as Joe in post of 1/29/16 (Older Maytag) Door latches, but i need to apply continual manual pressure
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » dishwasher won't start or run unless I apply pressure to door (even with tight closur
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 09-20-2018, 05:32 PM
Junior Member
tedf is on a distinguished road
Default dishwasher won't start or run unless I apply pressure to door (even with tight closur
Brand: Maytag   Age: More than 10 years
Same problem as Joe in post of 1/29/16 (Older Maytag) Door latches, but i need to apply continual manual pressure to door for dishwasher to start or run. I've tried adjusting the latch in or out but still seems to need pressure on the door -- (even if latch is so loose that it leaks when running). I had a professional repair person out about 3 1/2 months ago to the tune of $271 with same problem -- he made it run (with very tight fit) -- but only lasted about 3 mos.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher door wont latch tight pcharrison Dishwasher Repair 1 01-18-2013 01:59 PM
door will not close tight btk4962 Oven Repair (including Ranges and Cooktops) 1 04-29-2012 01:57 AM
GE Profile washer makes squeaky sound and when i apply pressure to the inside of the gordonprimeaux Washer Repair 1 05-13-2009 09:25 AM
Dishwasher Door doesn't close tight to activate wash mydogsmom Dishwasher Repair 6 10-18-2008 10:11 PM
Door not closing tight lvskipper Refrigerator & Freezer Repair 1 09-09-2008 09:33 AM
