Hi all, Hope I will get some solutions for my issue with my old GE Dishwasher. First I saw the detergent not dissolved and fell down in the bottom tray near the center arm. Utensils are not clean, food particles stuck on them.
Checked drain filter/blades (behind the center arm), cleaned, nothing clogged now. Center arm and top arm are clean.
Now, again I ran full cycle. Looks like Detergent dissolved now, I can't see any detergent at bottom. Heard the sound of splashing water / Draining good.
Used Lemi Shine- Booster with detergent. I can't see bigger food particles now, but still seeing some stains/films in the utensils. I tested with only few small utensils.
Do I need to pull out the dishwasher and check pumps/inlet valve? Can you guys please suggest me best parts store and Part # finder for my model? I do not have a manual now.
Thanks in advance.
